I’m using Raspberry Pi 4 and have searched the forums, following the advice to install and set permissions for chromium-docker.
After 4 uninstalls and reinstalls, I’ve finally got it working, but I think it’s limping along.
Currently, when I open the settings page, I get the “Aw, Snap!” message every time.
Any suggestions I could try?
boot/config.txt
#gpu_mem=64
test?
That never worked. So it is a known issue since the beginning.
Well, there are worse things! I’m happy it’s working as it is and appreciate the work done on this.
system
Closed
5
