Hey guys, i am using Manjaro at my work laptop and i have noticed a weird behavior lately. Whenever i keep closing and opening instances of Chromium and gnome terminal at certain point the keyboard is not detected in those applications no matter what i do. All i can do is logout of restart? any idea what could be causing this.
EDIT: behavior unexpected sometimes even mozilla doesn’t recognize keyboard typing
my config:
➜ ~ inxi -Fzxxxa
Kernel: 6.1.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=7cc45808-af75-44ae-bc03-0b6298802e98 rw quiet splash apparmor=1
Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 info: docker wm: gnome-shell
dm: GDM v: 44.1 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81YQ v: IdeaPad 5 15ARE05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 15ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0T76446WIN
serial: <superuser required> UEFI: LENOVO v: E7CN46WW date: 05/16/2022
ID-1: BAT0 charge: 40.1 Wh (96.2%) condition: 41.7/45.0 Wh (92.6%)
volts: 12.2 min: 11.1 model: Celxpert L19C3PF4 type: Li-poly
serial: <filter> status: not charging cycles: 119
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1857 high: 2000 min/max: 1400/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1398 2: 2000
3: 1462 4: 2000 5: 2000 6: 2000 7: 2000 8: 2000 bogomips: 31958
Type: spec_rstack_overflow mitigation: SMT disabled
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 47.0 C
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 5986:212b
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x08d5 built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.7-1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM 16.0.6 DRM
3.49 6.1.53-1-MANJARO) device-ID: 1002:1636 memory: 500 MiB unified: no
display-ID: :0.0
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.53-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off tools: pw-cli
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 7 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 135.56 GiB (28.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNT512G MEMORY size: 476.94 GiB block-size: physical: 512 B
fw-rev: 0109AELA temp: 35.9 C scheme: GPT
ID-1: / raw-size: 231.42 GiB size: 226.73 GiB (97.97%)
used: 135.52 GiB (59.8%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
used: 45.6 MiB (47.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 63.5 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): N/A
Processes: 299 Uptime: 1d 1h 11m wakeups: 5 Memory: total: 16 GiB note: est.
available: 15 GiB used: 5.48 GiB (36.5%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1558 libs: 370
tools: gnome-software,pamac,paru,yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.30
