After reinstalling Manjaro I noticed that Checksums tab is missing from file properties. I checked in settings and etc, can’t find how to turn it on. Google is useless as well
Help, I really like this feature.
Not all files have a Checksum check property, same with Folders - Checksum is not calculable hence the tab will be missing. For example, your .bashrc
file, right click on it, go to Properties and you will see that you can access the Checksum tab for it …
