There was a huge update package today which updated 176 different packages. It included a new Chromium. Everything 3d rendered in Chromium is flickering like crazy now.
Hi @Sam_Fisher
Your post has been moved to the topic you already created. Please try to keep your topics contained.
I have taken the liberty of adding the chromium tag to benefit topic discovery through forum Search.
Itās a mesa regression 24.2.7 to 24.3. firefox too have problem with 3d rendering (earth google) and website with transparency layer like X. But no one has made a bug report, no time to do that.
A link to any related information might be a welcome addition; Iām sure the OP will appreciate it.
No link because no bug report. Simply reverse packages. If others confirm then bug is confirmed .Darsky has confirmed.
env MESA_DEBUG=1 MOZ_LOG="PlatformDecoderModule:5,Layers:5,WebGL:5" firefox
go to earth google
GetShaderInfoLog() ->
0:2(12): error: extension `GL_EXT_shader_texture_lod' unsupported in fragment shader
GetShaderSource() ->
#extension GL_EXT_shader_texture_lod: require
void main() {}
void main() {}
Crash Annotation GraphicsCriticalError: |[C0][GFX1-]: Couldn't sanitize GL_RENDERER "V3D 7.1.7.0" (t=29.3142) [GFX1-]: Couldn't sanitize GL_RENDERER "V3D 7.1.7.0"
void main() {}
Crash Annotation GraphicsCriticalError: |[C0][GFX1-]: Couldn't sanitize GL_RENDERER "V3D 7.1.7.0" (t=29.3142) |[C1][GFX1-]: Couldn't sanitize GL_RENDERER "V3D 7.1.7.0" (t=29.3422) [GFX1-]: Couldn't sanitize GL_RENDERER "V3D 7.1.7.0"
Crash Annotation GraphicsCriticalError: |[C0][GFX1-]: Couldn't sanitize GL_RENDERER "V3D 7.1.7.0" (t=29.3142) |[C1][GFX1-]: Couldn't sanitize GL_RENDERER "V3D 7.1.7.0" (t=29.3422) |[C2][GFX1-]: Couldn't sanitize GL_RENDERER "V3D 7.1.7.0" (t=30.5301) [GFX1-]: Couldn't sanitize GL_RENDERER "V3D 7.1.7.0"
That all i knows
OK, I see it will be easier to ping @Darksky directly for any related information. Cheers.
Thanks for the info. I will try to revert mesa package to its previous version and see if it will fix things for me. The issue is our sole āpackage archiveā which is āhttp://tardis.tiny-vps.com/aarm/ā sometimes work, sometimes doesnāt.
check /var/cache/pacman/pkg/. The last 3 archived packages are here.
Package (4) Old Version New Version Net Change
mesa 1:24.3.1-3 1:24.2.7-1 15.76 MiB
opencl-rusticl-mesa 1:24.3.1-3 1:24.2.7-1 -2.32 MiB
vulkan-broadcom 1:24.3.1-3 1:24.2.7-1 -0.13 MiB
vulkan-mesa-layers 1:24.3.1-3 1:24.2.7-1 -0.45 MiB
I can confirm that after downgrading the āmesaā package, the 3d rendering issue of Chromium has been resolved. I put a āignorepkgā tag to mesa for the time being. So yeah, thanks for the quick help.
Then we need a volunteer to make a bug report to mesa gitlabā¦
So i see that in your list, you reverted not just āmesaā but three more packages. Should i also revert the others like you did?
I would say that mixing packages in this case can lead to problems
I filed a bug report. Hopefuly the information will be enough. Could not post any logs though.
mesa-24.3.1 was 2 version behind ā 24.3.3
iām more or less in the same boat as you but on x86. iām unaware of the branches you are in, but āunstableā just upgraded to llvm-libs 19.x. mesa 24.2.7 explicitly depend on llvm 18, so when that upgrade to llvm hits you, you will have issues (in my case chrome didnt even start, basically anything depending on mesa stack will fail). so when you get the upgrade to llvm-libs 18.x ā 19.x update, you will have to additionally install llvm18-libs
to keep everything functional.
iām not sure whether i can relate the issues iāve been having with yours since we are on different platforms (x86 vs ARM), but for information sake, can you share the links to you prospective bugs for referral.
mesa 24.3.3
Could you test. Warning after the upcoming update (clang et llvm) this mesa will not work.
Patch included
Could you correct the title itās more mesa 24.3 render problem
