Hi. I getting a error message during I try to create a shortcut for second chrome user.
Executing in terminal:
/usr/bin/google-chrome-stable --profile-=“Profile 2”
Every time terminal is trying to create new Profile inside a profile’s folder which already exist.
Does anyone have idea how to easy create a desktop shortcut?
I have looked, but not very far or thoroughly, but:
(why) are you sure that this command should work as intended?
(starting a chrome instance with this specific profile?)
edit:
I had a look at
man google-chrome-stable
and it seems this can be done via this option:
--user-data-dir=DIR
Specifies the directory that user data (your "profile") is kept in. Defaults to $HOME/.config/google-chrome . Separate instances of Google Chrome
must use separate user data directories; repeated invocations of google-chrome will reuse an existing process for a given user data directory.
