Hello,
I have been using Manjaro XFCE in different machines for many years.
A couple of weeks ago I opted for installing the KDE Plasma version on a desktop machine with very standard hardware (vide infra). I must mention that I performed the installation offline because the proxy was not configured.
$XDG_SESSION_TYPE reports x11 but I have noticed that KDE Plasma depends on several Wayland-related packages which are therefore installed and cannot be removed.
I have not tweaked the system configuration at all, it is a vanilla installation.
Sometimes the display partially freezes when trying to shutdown or restart from the GUI menus. In addition, sometimes I have issues logging in after restarting or when unlocking the screen after inactivity.
It does not happen all the time but I was wandering if there are other users experiencing the same behaviour.
I am currently running a custom kernel but the issues started right after installation and persisted until the installation of the new kernel. The symptoms with the new and the standard kernel are identical.
**inxi -Fza --no-host**
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=43f9b5a7-0a64-4fed-a951-044fb692e052 rw quiet splash
udev.log_priority=3 nowatchdog
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: LENOVO product: 10ST006UMB v: ThinkCentre M720s
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: LENOVO model: 312A v: SDK0J40697 WIN 3305327030540
serial: <superuser required> UEFI-[Legacy]: LENOVO v: M1UKT5CA
date: 09/21/2020
Info: model: Intel Core i5-9400 bits: 64 type: MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF4
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
desc: 1x9 MiB
Speed (MHz): avg: 2550 high: 2900 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 2900 3: 2900
4: 2900 5: 2900 6: 2900 bogomips: 34798
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e98 class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-2 model: Lenovo LEN T24i-20 serial: <filter> built: 2021
res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 238.47 GiB used: 29.24 GiB (12.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS256GD9TNI-L2B0B size: 238.47 GiB block-size: physical: 512 B
rev: 11710C10 temp: 23.9 C scheme: MBR
ID-1: / raw-size: 238.47 GiB size: 233.67 GiB (97.99%)
used: 29.24 GiB (12.5%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 30.0 C mobo: N/A
Processes: 209 Uptime: 44m wakeups: 5 Memory: 31.22 GiB
used: 3.54 GiB (11.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1214 libs: 342 tools: pamac Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
**sudo mhwd-kernel -li**
Currently running: 6.1.12-1-MANJARO (linux61)
* linux61
**sudo mhwd -li**
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
