Hey, I am trying to move to Wayland because of better support for multiple monitors and freesync.
I enabled native Wayland support for chrome by these flags:
--enable-features=UseOzonePlatform --ozone-platform=wayland
Chrome or any chromium based app with enabled Wayland support runs very slow, laggy and choppy.
testufo.com shows me around 40-58 fps. Firefox on wayland is incredible smooth.
Output from chrome:
[23724:23724:0716/195346.584735:ERROR:cursor_loader.cc(107)] Failed to load a platform cursor of type kNull
[23764:23764:0716/195346.607025:ERROR:gpu_init.cc(440)] Passthrough is not supported, GL is egl
[23764:23764:0716/195346.609357:ERROR:sandbox_linux.cc(374)] InitializeSandbox() called with multiple threads in process gpu-process.
This error messages I have on all chromium apps. I get this error messages only on Arch. Ubuntu is fine.
No matter what I do I can’t still get chromium run at 144fps to use my 144hz. I thought this problem can be solved by moving to Wayland but it’s not.
On X11 or xwayland chrome runs fine but only limited to 60 fps.
Some info
Kernel: 5.13.1-3-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b055c86b-0272-4469-9b69-13075d0bef0a rw quiet apparmor=1
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_wayland vt: 2 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
serial: <filter> UEFI: American Megatrends LLC. v: 1.60 date: 05/13/2021
RAM: total: 15.55 GiB used: 3.62 GiB (23.3%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 3 MiB bogomips: 86430
Speed: 3099 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3099 2: 2047 3: 2194 4: 2057 5: 2057 6: 3596 7: 2059 8: 2052 9: 3674
10: 2068 11: 2048 12: 3594
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 2b:00.0
chip-ID: 1002:67df class-ID: 0300
Display: wayland server: X.Org 1.21.1.2 compositor: kwin_wayland driver:
loaded: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 144 dpi: 81
size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
Monitor-2: XWAYLAND1 res: 1920x1080 hz: 60 dpi: 81
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.41.0
5.13.1-3-MANJARO LLVM 12.0.0)
v: 4.6 Mesa 21.1.4 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 2b:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2d:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-10:5 chip-ID: 0d8c:0005
class-ID: 0300 serial: <filter>
Device-4: COOLING.PL Zdziech Spolka Jawn VIRO Plus type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:3 chip-ID: 3299:4e4e
class-ID: 0300
Sound Server-1: ALSA v: k5.13.1-3-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.31 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 2.95 TiB used: 93.08 GiB (3.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 rotation: SSD serial: <filter> rev: S5Z42105 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZRZ-00Z5HB0
rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 5A scheme: GPT
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 93.08 GiB (42.6%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: b055c86b-0272-4469-9b69-13075d0bef0a
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 2C3A-83E1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: <superuser required>
label: N/A uuid: 387D-31F5
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 930.85 GiB
fs: <superuser required> label: N/A uuid: 027A82FD7A82ED2B
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 560 MiB fs: <superuser required>
label: N/A uuid: 94C42BA4C42B8816
ID-5: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: <superuser required>
label: N/A uuid: 368EAD708EAD28F7
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-7:3 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c56 class-ID: 0300 serial: <filter>
Device-2: 1-9:4 info: Itron iONE TESORO GRAM XS type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 195d:2058 class-ID: 0301
Device-3: 1-10:5 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Razer USA RZ01-0265 Gaming Mouse [Basilisk Essential]
type: Mouse,Keyboard driver: razermouse,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0065 class-ID: 0300
Device-2: 3-3:3 info: COOLING.PL Zdziech Spolka Jawn VIRO Plus
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 3299:4e4e class-ID: 0300
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 45.1 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 2219
Processes: 303 Uptime: 1h 34m wakeups: 0 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1310 lib: 390
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.05
