I installed google-chrome-beta from add/remove software app but it doesn’t show in search and in the application list too. What should I do?
Probably you have to log out and back in.
What happens if you run from terminal google-chrome-beta
? Any error ?
Okay, I just required a reboot, which I never needed before which is weird but anyway, it worked. Thanks!
