请问China的mirror只有三个吗? 我记得之前有huawei的
https://repo.manjaro.org 里面China的mirror只有3个了, 我不久前记得有5个的, 包括huawei的, 现在只剩3个了, pacman-mirror工具也貌似只有三个了, 但是打开huawei的 https://mirrors.huaweicloud.com/manjaro/ 发现还在正常更新的, 有谁知道是什么情况吗?
Mirrors in China - often - cannot be reached from other countries.
This may - some times incorrectly - result in mirrors being removed from list.
Translate using Google
通常无法从其他国家到达中国的镜子。
这可能(有时是错误地)导致从列表中删除镜像。
repo里面那个 mirrors.json.offline和mirrors.json.outdated文件竟然是手动修改的而不是自动获取的, 厉害了
还有"Mirrors in China - often - cannot be reached from other countries.
This may - some times incorrectly - result in mirrors being removed from list."
这段话是哪里看到的?
If the translation is wrong - sorry - used Google - I have no idea what Google translated it to.
So - skip translating - just plain english.
The web service checks all mirrors for their status at least 50 times a day. ( I don't know the actual count )
When the a mirror does not answer - or the mirror is not up-to-date - for a longer period the mirror is manually moved to backup files.
We cannot know when a mirror is back online - the maintainer of the mirror needs to contact Manjaro. The mirror mailinglist is a good place.
Even inside China, the available mainland mirrors are very slow. Hong Kong mirrors, however are quite reasonable, and they work with/without a VPN.
Grr, the 'reply' on this forum is a complete mess!
Thanks, I got it now. I'm gonna keep using mirrors in repo.manjaro.org/pacman-mirrors.
Actually inside China, for me the available mainland mirrors are not slow, when I use command like sudo pacman-mirrors -f 5 to get the top 5 fastest mirrors, the mirrors are always from Mainland China, HongKong and Taiwan.
That's simply unture
http://www.site24x7.com/public/t/results-1572512358013.html
http://www.site24x7.com/public/t/results-1572836766991.html
it's widely avaliable
And I wonder why the state of mirrors in China is always marked "unknown"?
The state file of the repos are widely avaliable and have onpar sync with other "Up to date" mirrors, maybe manjaro need to get better on the mirror detecting, like arch ?
