I have installed Cheese app, and see vertical lines in the app window. However, when I take a picture all is OK. How can I remove the multiple vertical lines in the app window? Thank you.
It looks like interference - perhaps a mode setting - Clock the hamburger in upper right corner - explore your options.
Thank you for the reply. I checked there, and in Preferences. However, there didn’t seem to be anything I could change. In fact, the options in Preferences seemed unresponsive.
I don’t know - I have rarely need for webcam - the times I do I use the package guvcview
I know that a change in Gnome toolkit removed access to some settings in Cheese - but that is years ago - at that point someone patched cheese to remove CSD (client side decoration) for gaining access to the settings.
I suggest you uninstall Cheese and try the other package.
Guessing from the window decoration you could be using KDE/Plasma
There is both guvcview-qt and kamoso.
kamoso however lacks the configuration options available with guvcview.
Be aware that first time the settings window most likely overlaps the video - just move the settings window.
kamoso is the native webcam on KDE Plasma
Thank you for the advice. I will carry out your suggestions and report back later.
Thanks for this. I didn’t know it was default for KDE. I’ll check it out.
@PrettyPixel I can reproduce this issue. The final picture has no issues but the live preview is scrambled and show red and green lines. Note that this doesn’t happen if I select any other picture resolution other than the top 3 options in my case. There are bug reports about the same. You can continue using cheese
only as I don’t think live preview is a bid deal.
Thank you so much for confirming this is an issue and not just a problem with my system.
I uninstalled Cheese, and installed Kamoso. Many thanks to everyone.
