When I did checkrebuild:
$ checkrebuild foreign dropbox foreign popcorntime foreign ums
and after I rebuild the packages it still gives me the same packages to rebuild.
That’s odd. Are there still any files in /usr/lib/python3.8/site-packages/
No, there is no directory /usr/lib/python3.8 and there is no dependencies of python in dropbox, popcorntime or ums.
Ah, you’re right. What’s the verbose output?
checkrebuild -v
checkrebuild -v
foreign dropbox
foreign popcorntime
foreign ums
ldd /usr/share/popcorntime/lib/libnode.so
libnw.so => not found
ldd /usr/share/popcorntime/lib/libnw.so
libffmpeg.so => not found
ldd /opt/ums/jre15/lib/libzip.so
libjvm.so => not found
ldd /opt/ums/jre15/lib/libverify.so
ldd /opt/ums/jre15/lib/libsplashscreen.so
ldd /opt/ums/jre15/lib/libsctp.so
ldd /opt/ums/jre15/lib/librmi.so
ldd /opt/ums/jre15/lib/libprefs.so
ldd /opt/ums/jre15/lib/libnet.so
ldd /opt/ums/jre15/lib/libnio.so
ldd /opt/ums/jre15/lib/libmlib_image.so
ldd /opt/ums/jre15/lib/libmanagement.so
ldd /opt/ums/jre15/lib/libmanagement_agent.so
ldd /opt/ums/jre15/lib/libmanagement_ext.so
ldd /opt/ums/jre15/lib/liblcms.so
ldd /opt/ums/jre15/lib/libjsound.so
ldd /opt/ums/jre15/lib/libjimage.so
ldd /opt/ums/jre15/lib/libjdwp.so
ldd /opt/ums/jre15/lib/libjawt.so
ldd /opt/ums/jre15/lib/libjava.so
ldd /opt/ums/jre15/lib/libjavajpeg.so
ldd /opt/ums/jre15/lib/libinstrument.so
ldd /opt/ums/jre15/lib/libfontmanager.so
ldd /opt/ums/jre15/lib/libextnet.so
ldd /opt/ums/jre15/lib/libawt_xawt.so
ldd /opt/ums/jre15/lib/libawt.so
ldd /opt/ums/jre15/lib/libawt_headless.so
ldd /opt/dropbox/_yappi.cpython-37m-x86_64-linux-gnu.so
libffi.so.6 => not found
ldd /opt/dropbox/tprt.cpython-37m-x86_64-linux-gnu.so
libdropbox_tprt.so => not found
ldd /opt/dropbox/nucleus_python.cpython-37m-x86_64-linux-gnu.so
libdropbox_nucleus.so => not found
ldd /opt/dropbox/libQt5WebKit.so.5
libicui18n.so.42 => not found
libicuuc.so.42 => not found
libicudata.so.42 => not found
ldd /opt/dropbox/libQt5Core.so.5
ldd /opt/dropbox/libicuuc.so.42
ldd /opt/dropbox/libicui18n.so.42
ldd /opt/dropbox/_ctypes.cpython-37m-x86_64-linux-gnu.so
ldd /opt/dropbox/apex._apex.cpython-37m-x86_64-linux-gnu.so
libdropbox_apex.so => not found
ldd /opt/dropbox/_cffi_backend.cpython-37m-x86_64-linux-gnu.so
If the aforementioned programs are running normally, I wouldn’t worry about it. Have you rebooted since?
Some of the libs are in they’re places although “ldd” says “not found”, others are in a subdirectory.
Yes, that’s what I thought. Everything is working.
Related issue:
