I am new to linux in general.
I am fed up with windows and have fell in love with Manjaro.
My issue is in my build I have a 500g ssd for my boot partition and I have a 4tb hdd for everything else.
I would like to be able to change the default save locations for everything to go to the hdd instead of the m.2. Please help.
inxi -Fazy --filter will not let me post the results because it says there is a link
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 164.8M 1 loop /var/lib/snapd/snap/gnome-3-28-1804/161
loop1 7:1 0 65.2M 1 loop /var/lib/snapd/snap/gtk-common-themes/1519
loop2 7:2 0 32.3M 1 loop /var/lib/snapd/snap/snapd/13170
loop3 7:3 0 55.4M 1 loop /var/lib/snapd/snap/core18/2128
loop4 7:4 0 82.9M 1 loop /var/lib/snapd/snap/discord/130
loop5 7:5 0 4K 1 loop /var/lib/snapd/snap/bare/5
sda 8:0 0 3.6T 0 disk
└─sda1 8:1 0 3.6T 0 part /run/media/cory/c6b07522-34eb-4439-b440-07ba629b4d6a
sdb 8:16 1 28.5G 0 disk
├─sdb1 8:17 1 3.2G 0 part
└─sdb2 8:18 1 4M 0 part
nvme0n1 259:0 0 465.8G 0 disk
├─nvme0n1p1 259:1 0 300M 0 part /boot/efi
└─nvme0n1p2 259:2 0 465.5G 0 part
└─luks-d502560c-19ab-4397-9e62-38281ab743b9 254:0 0 465.5G 0 crypt /
Use 3 backticks ``` at start beginning and end of the output to format it.
root=UUID=3410013f-fb41-4274-9a99-7b105d040a1d rw quiet
cryptdevice=UUID=d502560c-19ab-4397-9e62-38281ab743b9:luks-d502560c-19ab-4397-9e62-38281ab743b9
root=/dev/mapper/luks-d502560c-19ab-4397-9e62-38281ab743b9 apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
serial: <filter> UEFI: American Megatrends v: A.70 date: 01/09/2020
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache:
L2: 4 MiB
bogomips: 128032
Speed: 3999 MHz min/max: 2200/4000 MHz boost: enabled Core speeds (MHz):
1: 3999 2: 3997 3: 4000 4: 4001 5: 4005 6: 4000 7: 4002 8: 4004 9: 3999
10: 3993 11: 4007 12: 3998 13: 3991 14: 3999 15: 4007 16: 4000
conditional, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: eVga.com.
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 2d:00.0
chip-ID: 10de:21c4 class-ID: 0300
Device-2: Generalplus 808 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2.1.3.2:25 chip-ID: 1b3f:2002 class-ID: 0102
Screen-1: 0 s-res: 5760x1080 s-dpi: 80 s-size: 1828x342mm (72.0x13.5")
s-diag: 1860mm (73.2")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 82
size: 595x336mm (23.4x13.2") diag: 683mm (26.9")
Monitor-2: HDMI-0 res: 1920x1080 dpi: 81 size: 600x340mm (23.6x13.4")
diag: 690mm (27.2")
Monitor-3: DP-0 res: 1920x1080 hz: 60 dpi: 82 size: 595x336mm (23.4x13.2")
diag: 683mm (26.9")
OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: C-Media USB Advanced Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.1.2.3:18
chip-ID: 0d8c:01c2 class-ID: 0300
Device-4: Generalplus 808 Camera type: USB driver: snd-usb-audio,uvcvideo
Device-5: C-Media USB Advanced Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.1.3.3:16
Device-6: C-Media USB Advanced Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.3.3:7
Device-7: Astro Gaming Astro A50 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.4.4.2:14
chip-ID: 9886:002c class-ID: 0300
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel port: d000
bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.12 TiB used: 12.94 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN008-2DR166
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5980 serial: <filter> rev: SC60 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Transcend
model: JetFlash Transcend 32GB size: 28.48 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 12.94 GiB (2.8%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-d502560c-19ab-4397-9e62-38281ab743b9
used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 44.9 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 39%
Processes: 363 Uptime: 4h 29m wakeups: 0 Memory: 31.3 GiB used: 3 GiB (9.6%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: N/A Packages: 1216
pacman: 1209 lib: 332 flatpak: 0 snap: 7 Shell: Zsh v: 5.8 default: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.06```
Do the same formatting for lsblk output and please remove the ARM tag as you are running a x86_64 based CPU.
Sorry about that mislabel
The common practice is to mount your hdd to /home
. But i suppose you already have content on that drive, so there’d be a bit of moving things around.
Before we come to this, just checking something: what file system do you use on that hard drive?
I just formated the drive for ext4 so the drive is empty
If you can reinstall:
- use manual partitioning
- set the EFI partition to mount to
/boot/efi
(if relevant) - set your m2 to mount to
- set your hdd to mount to
/home
If you don’t want to reinstall:
- copy everything from
/home
to your hard drive - edit
/etc/fstab
to mount your drive to/home
: [root tip] Mount partition using fstab - reboot
- confirm your drive is currently mounted to
/home
- confirm your system works well
- boot into a LiveUSB
- delete the content of
/home
from your m2
Also, i spot that you encrypted your root partition, but your hdd is not. If you want to encrypt your data, you should change its partitioning beforehand.
I will reinstall and try it that way.
That is way too much - 1 single Gigabyte is plenty more than you’ll ever need for that.
The /boot directory only holds the kernel images …
and it will not be writable (aka: usable) by a normal user of the system as a storage location.
If you meant where the system is installed, but not the users $HOME directory -
it’s still way too much
50 GB or even 100 GB if you are using snaps or flatpacks should be overkill
please consider that on your reinstall
I changed it on the reinstall but now the updates take forever and it will not install the video-nvidia hardware config, whereas it did all of it just fine earlier any suggestions? Although, now I do have my 4tb hdd available and that is where everything is being stored.
Refresh your mirror list to pick a faster one:
sudo pacman-mirrors -f 5
You can also configure it to use only mirrors close to you. Details in
man pacman-mirrors
