Changing volume too fast causes system restart
Hello. First I will write my specs:
CPU: AMD Ryzen 5 2600 overclocked to 4,1 GHz
RAM: 16GB 3000MHz CL16
GPU: Gainward Phoenix RTX 2060 GS
MOBO: MSI B450-A PRO
SSD: Samsung 970 EVO Plus 500GB
Sound Card: Asus Xonar DGX
Dual boot Windows 10 and Manjaro KDE
When I am turning volume up and down very quickly, my computer is restarting. Then, after choosing Manjaro in GRUB menu, i can see for a few seconds this output:
[ 0.297044] mce: [Hardware Error]: CPU 5: Machine Check: 0 Bank 0: be80280000
0c0135
[ 0.297044] mce: [Hardware Error]: TSC 0 ADDR fffdfc00d080 MISC d012000000000
000 IPID b000000000
[ 0.297044] mce: [Hardware Error]: PROCESSOR 2:800f82 TIME 1601135477 SOCKET
0 APIC c microcode 800820d
Then, system normally starts up.
Also sometimes, when I am starting YouTube video, system can also restart and show the same output like above.
On top of that, sometimes when I shutdown my computer, it is shutting down for 1 minute (when it normally takes 5 seconds), and after that 1 minute same output is shown.
I think it might have some relation with my dedicated soundcard. There are no native drivers for Linux for my soundcard, so I am forced to use these ones installed by default. If this can matter, I am plugging my headphones and microphone to front panel (i connected HD Audio header to my Xonar DGX).
Just checking in - don’t have a solution, unfortunately, but I have the same strange problem when changing the volume quickly. The PC just resets and displays the hardware errors on the next start. My setup is pretty similar: Ryzen 5 2600, ASRock B450 Pro4 and ASUS Xonar DGX. Stable branch, kernel 5.4.72-1.
Is @x264 's CPU overclocked as well?
Can you both provide the boot log from the previous boot (last 25 lines should be good)
journalctl --system --boot=-1 | tail --lines=25
:thinking:
Information at alsa-project.org -Asus shows Xonar DGX (CMI8786) has Linux support since kernel 3.14 with driver snd_oxygen
But Ryzen B450 motherboards have been mentioned a few times on this forum as having problems with onboard audio
I suggest you try a later kernel v5.8 or v5.9 that may have better support for your CPU/motherboard
if that does not help, I suggest you get more information about audio devices with
sudo alsa-info.sh --upload
No, I’m not running an overclock. The resetting behavior is very sporadic for me and not easily reproducible - it’s happened maybe three or four times, with lots of time inbetween:
[xxx@manjaro ~]$ journalctl --system | grep 'Hardware Error'
Jul 22 07:57:31 manjaro kernel: mce: [Hardware Error]: Machine check events logged
Jul 22 07:57:31 manjaro kernel: mce: [Hardware Error]: CPU 5: Machine Check: 0 Bank 0: be802800000c0135
Jul 22 07:57:31 manjaro kernel: mce: [Hardware Error]: TSC 0 ADDR fffdfc00e080 MISC d012000000000000 IPID b000000000
Jul 22 07:57:31 manjaro kernel: mce: [Hardware Error]: PROCESSOR 2:800f82 TIME 1595397446 SOCKET 0 APIC 5 microcode 8008206
Okt 30 21:17:09 manjaro kernel: mce: [Hardware Error]: Machine check events logged
Okt 30 21:17:09 manjaro kernel: mce: [Hardware Error]: CPU 5: Machine Check: 0 Bank 0: be802800000c0135
Okt 30 21:17:09 manjaro kernel: mce: [Hardware Error]: TSC 0 ADDR fffdfc00e080 MISC d012000000000000 IPID b000000000
Okt 30 21:17:09 manjaro kernel: mce: [Hardware Error]: PROCESSOR 2:800f82 TIME 1604089025 SOCKET 0 APIC 5 microcode 8008206
These are the last lines from the boot that was reset:
[xxx@manjaro ~]$ journalctl --system --boot=-4 | tail --lines=25
Okt 30 21:06:25 manjaro ntfs-3g[14287]: [96B blob data]
Okt 30 21:06:25 manjaro ntfs-3g[14287]: [94B blob data]
Okt 30 21:06:25 manjaro ntfs-3g[14287]: [97B blob data]
Okt 30 21:07:53 manjaro nmbd[562]: [2020/10/30 21:07:53.839590,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
Okt 30 21:07:53 manjaro nmbd[562]:   query_name_response: Multiple (2) responses received for a query on subnet 10.0.0.220 for name WORKGROUP<1d>.
Okt 30 21:07:53 manjaro nmbd[562]:   This response was from IP 10.0.0.18, reporting an IP address of 10.0.0.18.
Okt 30 21:12:54 manjaro nmbd[562]: [2020/10/30 21:12:54.369523,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
Okt 30 21:12:54 manjaro nmbd[562]:   query_name_response: Multiple (2) responses received for a query on subnet 10.0.0.220 for name WORKGROUP<1d>.
Okt 30 21:12:54 manjaro nmbd[562]:   This response was from IP 10.0.0.18, reporting an IP address of 10.0.0.18.
Okt 30 21:13:20 manjaro audit[25105]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 pid=25105 comm="Civ5XP" exe=2F6D6E742F766F6C756D652F537465616D4C6962726172792F737465616D617070732F636F6D6D6F6E2F536964204D65696572277320436976696C697A6174696F6E20562F436976355850 sig=11 res=1
Okt 30 21:13:20 manjaro kernel: Civ5XP[25328]: segfault at 0 ip 0000000008cd8534 sp 000000007c8fefc0 error 4 in Civ5XP[8048000+22a7000]
Okt 30 21:13:20 manjaro kernel: Code: 00 00 00 00 5b 81 c3 f2 ea 62 01 8b b4 24 88 00 00 00 8b bc 24 84 00 00 00 8b 94 24 80 00 00 00 0f b7 87 88 00 00 00 8b 4a 04 <8b> 2c 81 85 ed 0f 84 ef 00 00 00 8b 0a 8b 52 08 89 54 24 20 f3 0f
Okt 30 21:13:20 manjaro kernel: audit: type=1701 audit(1604088800.011:78): auid=1000 uid=1000 gid=1000 ses=2 pid=25105 comm="Civ5XP" exe=2F6D6E742F766F6C756D652F537465616D4C6962726172792F737465616D617070732F636F6D6D6F6E2F536964204D65696572277320436976696C697A6174696F6E20562F436976355850 sig=11 res=1
Okt 30 21:13:20 manjaro systemd[1]: Started Process Core Dump (PID 25330/UID 0).
Okt 30 21:13:20 manjaro kernel: audit: type=1130 audit(1604088800.024:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@2-25330-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 30 21:13:20 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@2-25330-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 30 21:13:27 manjaro systemd[1]: systemd-coredump@2-25330-0.service: Succeeded.
Okt 30 21:13:27 manjaro kernel: audit: type=1131 audit(1604088807.534:80): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@2-25330-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 30 21:13:27 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@2-25330-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
I was running Civ 5 in Steam and it crashed out (Proton life :wink:). Changed the volume a couple minutes later, then the system reset.
Urgh! Not reproducible: They’re the worst to debug….
  • As per @nikgnomic: Are you on 5.8 / 5.9 and what’s the output of sudo alsa-info.sh --upload ???
  • Did you perform a memtest already?
:thinking:
Here’s my alsa-info.sh output (looks like my user isn’t allowed to post links, so I have to dump the whole thing here):
!!ALSA Information Script v 0.4.65
!!Script ran on: Mon Nov  2 12:53:45 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      To Be Filled By O.E.M.
Product Name:      To Be Filled By O.E.M.
Product Version:   To Be Filled By O.E.M.
Firmware Version:  P1.50
Board Vendor:      ASRock
Board Name:        B450 Pro4
!!ACPI Device Status Information
/sys/bus/acpi/devices/AMDI0030:00/status 	 15
/sys/bus/acpi/devices/AMDIF030:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0501:00/status 	 15
/sys/bus/acpi/devices/PNP0A08:00/status 	 15
/sys/bus/acpi/devices/PNP0C01:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:01/status 	 15
/sys/bus/acpi/devices/PNP0C02:03/status 	 15
/sys/bus/acpi/devices/PNP0C0C:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:01/status 	 11
/sys/bus/acpi/devices/PNP0C0F:02/status 	 11
/sys/bus/acpi/devices/PNP0C0F:03/status 	 11
/sys/bus/acpi/devices/PNP0C0F:04/status 	 11
/sys/bus/acpi/devices/PNP0C0F:05/status 	 11
/sys/bus/acpi/devices/PNP0C0F:06/status 	 11
/sys/bus/acpi/devices/PNP0C0F:07/status 	 11
!!Kernel Information
Kernel release:    5.4.72-1-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.4.72-1-MANJARO
Library version:    1.2.3.2
Utilities version:  1.2.3
!!Loaded ALSA modules
snd_oxygen
snd_hda_intel
snd_hda_intel
snd_usb_audio
snd_usb_audio
!!Sound Servers on this system
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [DGX            ]: CMI8786 - Xonar DGX
                      C-Media Oxygen HD Audio at 0xe000, irq 34
 1 [HDMI           ]: HDA-Intel - HDA ATI HDMI
                      HDA ATI HDMI at 0xfe860000 irq 86
 2 [Generic        ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xfe700000 irq 88
 3 [Aureon51MkII   ]: USB-Audio - Aureon5.1MkII
                      TerraTec Aureon5.1MkII at usb-0000:28:00.3-3, full speed
 4 [HD5000         ]: USB-Audio - Microsoft® LifeCam HD-5000
                      Microsoft Microsoft® LifeCam HD-5000 at usb-0000:03:00.0-10, high speed
!!PCI Soundcards installed in the system
23:04.0 Multimedia audio controller [0401]: C-Media Electronics Inc CMI8788 [Oxygen HD Audio] [13f6:8788]
	Subsystem: ASUSTeK Computer Inc. CMI8786 (Xonar DGX) [1043:8521]
27:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1002:aaf0]
	Subsystem: ASUSTeK Computer Inc. Device [1043:aaf0]
29:00.3 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller [1022:1457]
	Subsystem: ASRock Incorporation Device [1849:6893]
!!Loaded sound module options
!!Module: snd_oxygen
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	dmic_detect : N
	enable_msi : -1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 0
	power_save_controller : N
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
	dmic_detect : N
	enable_msi : -1
	pm_blacklist : Y
	power_save : 0
	single_cmd : -1
	snoop : -1
!!Module: snd_usb_audio
	autoclock : Y
	device_setup : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	ignore_ctl_error : N
	pid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	quirk_alias : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	use_vmalloc : Y
	vid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	autoclock : Y
	use_vmalloc : Y
!!HDA-Intel Codec information
--startcollapse--
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100700
No Modem Function Group found
Default PCM:
    rates [0x70]: 32000 44100 48000
    bits [0x2]: 16
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Converter: stream=0, channel=0
  Digital: Enabled
  Digital category: 0x0
  IEC Coding Type: 0x0
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=0, device=0
  Control: name="IEC958 Playback Pro Mask", index=0, device=0
  Control: name="IEC958 Playback Default", index=0, device=0
  Control: name="IEC958 Playback Switch", index=0, device=0
  Pincap 0x00000094: OUT Detect HDMI
  Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
    DefAssociation = 0xf, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=01, enabled=1
  Connection: 1
     0x02
Node 0x04 [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital: Enabled
Node 0x05 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=1, device=0
  Control: name="IEC958 Playback Pro Mask", index=1, device=0
  Control: name="IEC958 Playback Default", index=1, device=0
  Control: name="IEC958 Playback Switch", index=1, device=0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=02, enabled=1
  Connection: 1
     0x04
Node 0x06 [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital: Enabled
Node 0x07 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=2, device=0
  Control: name="IEC958 Playback Pro Mask", index=2, device=0
  Control: name="IEC958 Playback Default", index=2, device=0
  Control: name="IEC958 Playback Switch", index=2, device=0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=03, enabled=1
  Connection: 1
     0x06
Node 0x08 [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital: Enabled
Node 0x09 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=3, device=0
  Control: name="IEC958 Playback Pro Mask", index=3, device=0
  Control: name="IEC958 Playback Default", index=3, device=0
  Control: name="IEC958 Playback Switch", index=3, device=0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=04, enabled=1
  Connection: 1
     0x08
Node 0x0a [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital: Enabled
Node 0x0b [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=4, device=0
  Control: name="IEC958 Playback Pro Mask", index=4, device=0
  Control: name="IEC958 Playback Default", index=4, device=0
  Control: name="IEC958 Playback Switch", index=4, device=0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=05, enabled=1
  Connection: 1
     0x0a
Node 0x0c [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Converter: stream=1, channel=0
  Digital: Enabled
Node 0x0d [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=5, device=0
  Control: name="IEC958 Playback Pro Mask", index=5, device=0
  Control: name="IEC958 Playback Default", index=5, device=0
  Control: name="IEC958 Playback Switch", index=5, device=0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=06, enabled=1
  Connection: 1
     0x0c
Node 0x0e [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital:
Node 0x0f [Pin Complex] wcaps 0x400381: Stereo Digital
  Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x0e
Codec: Realtek ALC892
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0892
Subsystem Id: 0x18496893
Revision Id: 0x100302
Default PCM:
    rates [0x5f0]: 32000 44100 48000 88200 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 CLKSTOP EPSS
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Front Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Device: name="ALC892 Analog", type="Audio", device=0
  Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
  Amp-Out vals:  [0x2c 0x2c]
  Converter: stream=5, channel=0
  PCM:
    rates [0x560]: 44100 48000 96000 192000
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Surround Playback Volume", index=0, device=0
  PCM:
    formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Center Playback Volume", index=0, device=0
    ControlAmp: chs=1, dir=Out, idx=0, ofs=0
  Control: name="LFE Playback Volume", index=0, device=0
    ControlAmp: chs=2, dir=Out, idx=0, ofs=0
  PCM:
    formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
  PCM:
    formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  PCM:
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In caps: ofs=0x10, nsteps=0x2e, stepsize=0x03, mute=1
  Amp-In vals:  [0x1c 0x1c]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=1, device=0
  Control: name="Capture Switch", index=1, device=0
  Device: name="ALC892 Alt Analog", type="Audio", device=2
  Amp-In vals:  [0x80 0x80]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
  SDI-Select: 0
  Digital:
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Front Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=1, ofs=0
  Control: name="Front Mic Playback Switch", index=0, device=0
  Control: name="Rear Mic Playback Volume", index=0, device=0
  Control: name="Rear Mic Playback Switch", index=0, device=0
  Control: name="Line Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=2, ofs=0
  Control: name="Line Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 10
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x80 0x80]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  PCM:
    formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000010: OUT
  Pin Default 0x40000000: [N/A] Line Out at Ext N/A
    Conn = Unknown, Color = Unknown
    DefAssociation = 0x0, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
  Pincap 0x00000020: IN
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Front Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x0001003e: IN OUT HP EAPD Detect Trigger
  EAPD 0x2: EAPD
  Pin Default 0x01014010: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Green
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x00000036: IN OUT Detect Trigger
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Connection: 1
     0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Connection: 1
     0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Connection: 1
     0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Center Playback Switch", index=0, device=0
  Control: name="LFE Playback Switch", index=0, device=0
  Control: name="Rear Mic Boost Volume", index=0, device=0
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Pincap 0x00003736: IN OUT Detect Trigger
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x01a19030: [Jack] Mic at Ext Rear
    Conn = 1/8, Color = Pink
    DefAssociation = 0x3, Sequence = 0x0
  Pin-ctls: 0x21: IN VREF_50
  Connection: 5
     0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Front Mic Boost Volume", index=0, device=0
  Pincap 0x0000373e: IN OUT HP Detect Trigger
  Pin Default 0x02a19040: [Jack] Mic at Ext Front
    DefAssociation = 0x4, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Surround Playback Switch", index=0, device=0
  Control: name="Line Boost Volume", index=0, device=0
  Pin Default 0x0181303f: [Jack] Line In at Ext Rear
    Conn = 1/8, Color = Blue
    DefAssociation = 0x3, Sequence = 0xf
  Pin-ctls: 0x20: IN VREF_HIZ
  Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pincap 0x0001373e: IN OUT HP EAPD Detect Trigger
  EAPD 0x2: EAPD
  Pin Default 0x02214020: [Jack] HP Out at Ext Front
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP VREF_HIZ
  Connection: 5
     0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
  Pincap 0x00000024: IN Detect
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x4024c601: [N/A] HP Out at Ext N/A
    Conn = RCA, Color = UNKNOWN
    DefAssociation = 0x0, Sequence = 0x1
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=24
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 12
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Amp-Out vals:  [0x40 0x40]
  PCM:
    formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x25 0x0b
--endcollapse--
!!USB Mixer information
--startcollapse--
USB Mixer: usb_id=0x0ccd0028, ctrlif=0, ctlerr=0
Card: TerraTec Aureon5.1MkII at usb-0000:28:00.3-3, full speed
  Unit: 8
    Control: name="Capture Source", index=0
    Info: id=8, control=0, cmask=0x0, channels=1, type="U8"
    Volume: min=1, max=3, dBmin=0, dBmax=0
  Unit: 9
    Control: name="Master Playback Volume", index=0
    Info: id=9, control=2, cmask=0x0, channels=1, type="S16"
    Volume: min=-12256, max=-16, dBmin=-4787, dBmax=-6
  Unit: 9
    Control: name="Master Playback Switch", index=0
    Info: id=9, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
    Volume: min=0, max=1, dBmin=0, dBmax=0
  Unit: 10
    Control: name="Mic Capture", index=0
    Info: id=10, control=7, cmask=0x0, channels=1, type="BOOLEAN"
  Unit: 10
    Control: name="Mic Capture Volume", index=0
    Info: id=10, control=2, cmask=0x0, channels=1, type="S16"
    Volume: min=-48, max=6096, dBmin=-18, dBmax=2381
  Unit: 10
    Control: name="Mic Capture Switch", index=0
    Info: id=10, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
  Unit: 11
    Control: name="Line Capture Volume", index=0
    Info: id=11, control=2, cmask=0x3, channels=2, type="S16"
  Unit: 11
    Control: name="Line Capture Switch", index=0
    Info: id=11, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
  Unit: 12
    Control: name="IEC958 In Capture Switch", index=0
    Info: id=12, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
  Unit: 13
    Control: name="Mic Playback Volume", index=0
    Info: id=13, control=2, cmask=0x0, channels=1, type="S16"
    Volume: min=0, max=12240, dBmin=0, dBmax=4781
  Unit: 13
    Control: name="Mic Playback Switch", index=0
    Info: id=13, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
  Unit: 14
    Info: id=14, control=2, cmask=0x3, channels=2, type="S16"
  Unit: 14
    Info: id=14, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
USB Mixer: usb_id=0x045e076d, ctrlif=2, ctlerr=0
Card: Microsoft Microsoft® LifeCam HD-5000 at usb-0000:03:00.0-10, high speed
  Unit: 5
    Info: id=5, control=2, cmask=0x1, channels=1, type="S16"
    Volume: min=-5120, max=9216, dBmin=-2000, dBmax=3600
  Unit: 5
    Info: id=5, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
--endcollapse--
!!ALSA Device nodes
crw-rw----  1 root audio 116, 24 Nov  2 09:22 /dev/snd/controlC0
crw-rw----  1 root audio 116,  9 Nov  2 09:22 /dev/snd/controlC1
crw-rw----  1 root audio 116, 14 Nov  2 09:22 /dev/snd/controlC2
crw-rw----  1 root audio 116, 17 Nov  2 09:52 /dev/snd/controlC3
crw-rw----  1 root audio 116, 19 Nov  2 09:22 /dev/snd/controlC4
crw-rw----  1 root audio 116,  8 Nov  2 09:22 /dev/snd/hwC1D0
crw-rw----  1 root audio 116, 13 Nov  2 09:22 /dev/snd/hwC2D0
crw-rw----  1 root audio 116, 21 Nov  2 10:39 /dev/snd/pcmC0D0c
crw-rw----  1 root audio 116, 20 Nov  2 11:49 /dev/snd/pcmC0D0p
crw-rw----  1 root audio 116, 23 Nov  2 10:39 /dev/snd/pcmC0D1c
crw-rw----  1 root audio 116, 22 Nov  2 10:39 /dev/snd/pcmC0D1p
crw-rw----  1 root audio 116,  6 Nov  2 10:39 /dev/snd/pcmC1D10p
crw-rw----  1 root audio 116,  7 Nov  2 10:39 /dev/snd/pcmC1D11p
crw-rw----  1 root audio 116,  2 Nov  2 10:39 /dev/snd/pcmC1D3p
crw-rw----  1 root audio 116,  3 Nov  2 10:39 /dev/snd/pcmC1D7p
crw-rw----  1 root audio 116,  4 Nov  2 10:39 /dev/snd/pcmC1D8p
crw-rw----  1 root audio 116,  5 Nov  2 10:39 /dev/snd/pcmC1D9p
crw-rw----  1 root audio 116, 11 Nov  2 10:39 /dev/snd/pcmC2D0c
crw-rw----  1 root audio 116, 10 Nov  2 10:39 /dev/snd/pcmC2D0p
crw-rw----  1 root audio 116, 12 Nov  2 09:22 /dev/snd/pcmC2D2c
crw-rw----  1 root audio 116, 16 Nov  2 11:26 /dev/snd/pcmC3D0c
crw-rw----  1 root audio 116, 15 Nov  2 13:44 /dev/snd/pcmC3D0p
crw-rw----  1 root audio 116, 18 Nov  2 10:39 /dev/snd/pcmC4D0c
crw-rw----  1 root audio 116,  1 Nov  2 09:22 /dev/snd/seq
crw-rw----  1 root audio 116, 33 Nov  2 09:22 /dev/snd/timer
/dev/snd/by-id:
total 0
drwxr-xr-x 2 root root  80 Nov  2 09:52 .
drwxr-xr-x 4 root root 580 Nov  2 09:52 ..
lrwxrwxrwx 1 root root  12 Nov  2 09:52 usb-0ccd_USB_Audio-00 -> ../controlC3
lrwxrwxrwx 1 root root  12 Nov  2 09:22 usb-Microsoft_Microsoft®_LifeCam_HD-5000-02 -> ../controlC4
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 140 Nov  2 09:52 .
lrwxrwxrwx 1 root root  12 Nov  2 09:22 pci-0000:03:00.0-usb-0:10:1.2 -> ../controlC4
lrwxrwxrwx 1 root root  12 Nov  2 09:22 pci-0000:23:04.0 -> ../controlC0
lrwxrwxrwx 1 root root  12 Nov  2 09:22 pci-0000:27:00.1 -> ../controlC1
lrwxrwxrwx 1 root root  12 Nov  2 09:52 pci-0000:28:00.3-usb-0:3:1.0 -> ../controlC3
lrwxrwxrwx 1 root root  12 Nov  2 09:22 pci-0000:29:00.3 -> ../controlC2
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: DGX [Xonar DGX], device 0: Multichannel [Multichannel]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: DGX [Xonar DGX], device 1: Digital [Digital]
  Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 11: HDMI 5 [HDMI 5]
  Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 0: ALC892 Analog [ALC892 Analog]
  Subdevices: 1/1
card 3: Aureon51MkII [Aureon5.1MkII], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 2: ALC892 Alt Analog [ALC892 Alt Analog]
  Subdevices: 1/1
  Subdevices: 1/1
card 4: HD5000 [Microsoft® LifeCam HD-5000], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card DGX
Card hw:0 'DGX'/'C-Media Oxygen HD Audio at 0xe000, irq 34'
  Mixer name	: 'CMI8786'
  Components	: 'CS4245 CMI8786'
  Controls      : 22
  Simple ctrls  : 13
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch pswitch-joined
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 213 [84%] [-20.68dB] [on]
  Front Right: Playback 213 [84%] [-20.68dB] [on]
Simple mixer control 'Front Mic',0
  Capabilities: cvolume cswitch cswitch-joined cswitch-exclusive
  Capture exclusive group: 0
  Limits: Capture -24 - 24
  Front Left: Capture -24 [0%] [-12.00dB] [off]
  Front Right: Capture -24 [0%] [-12.00dB] [off]
Simple mixer control 'Line',0
  Front Left: Capture 24 [100%] [12.00dB] [on]
  Front Right: Capture 24 [100%] [12.00dB] [on]
Simple mixer control 'Mic',0
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [off]
Simple mixer control 'IEC958 Loopback',0
Simple mixer control 'IEC958 Validity Check',0
  Capabilities: cswitch cswitch-joined
  Capture channels: Mono
  Mono: Capture [off]
Simple mixer control 'Aux',0
Simple mixer control 'ADC High-pass Filter',0
  Capabilities: cenum
  Items: 'Active' 'Frozen'
  Item0: 'Active'
Simple mixer control 'Analog Input Monitor',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Limits: Playback 0 - 1
  Mono: Playback 1 [100%] [0.00dB] [off]
Simple mixer control 'Analog Output',0
  Capabilities: penum
  Items: 'Stereo Headphones' 'Stereo Headphones FP' 'Multichannel'
  Item0: 'Stereo Headphones'
Simple mixer control 'Digital Input Monitor',0
Simple mixer control 'Stereo Upmixing',0
  Capabilities: enum
  Items: 'Front' 'Front Surround'
  Item0: 'Front Surround'
!!-------Mixer controls for card HDMI
Card hw:1 'HDMI'/'HDA ATI HDMI at 0xfe860000 irq 86'
  Mixer name	: 'ATI R6xx HDMI'
  Components	: 'HDA:1002aa01,00aa0100,00100700'
  Controls      : 42
  Simple ctrls  : 6
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'IEC958',4
  Mono: Playback [on]
Simple mixer control 'IEC958',5
  Mono: Playback [on]
!!-------Mixer controls for card Generic
Card hw:2 'Generic'/'HD-Audio Generic at 0xfe700000 irq 88'
  Mixer name	: 'Realtek ALC892'
  Components	: 'HDA:10ec0892,18496893,00100302'
  Controls      : 39
  Simple ctrls  : 20
Simple mixer control 'Master',0
  Limits: Playback 0 - 64
  Mono: Playback 44 [69%] [-20.00dB] [on]
  Mono:
  Front Left: Playback 64 [100%] [0.00dB] [on]
  Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
  Mono:
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
  Mono:
Simple mixer control 'Center',0
  Mono: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'LFE',0
  Mono:
Simple mixer control 'Line Boost',0
  Limits: 0 - 3
Simple mixer control 'Capture',0
  Limits: Capture 0 - 46
  Front Left: Capture 28 [61%] [12.00dB] [on]
  Front Right: Capture 28 [61%] [12.00dB] [on]
Simple mixer control 'Capture',1
  Front Left: Capture 0 [0%] [-16.00dB] [off]
  Front Right: Capture 0 [0%] [-16.00dB] [off]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Enabled'
Simple mixer control 'Channel Mode',0
  Capabilities: enum
  Items: '2ch' '4ch' '6ch'
  Item0: '2ch'
Simple mixer control 'Input Source',0
  Capabilities: cenum
  Items: 'Front Mic' 'Rear Mic' 'Line'
  Item0: 'Front Mic'
Simple mixer control 'Input Source',1
  Capabilities: cenum
  Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
  Mono:
Simple mixer control 'Rear Mic Boost',0
  Limits: 0 - 3
!!-------Mixer controls for card Aureon51MkII
Card hw:3 'Aureon51MkII'/'TerraTec Aureon5.1MkII at usb-0000:28:00.3-3, full speed'
  Mixer name	: 'USB Mixer'
  Components	: 'USB0ccd:0028'
  Controls      : 16
  Simple ctrls  : 5
  Mono: Playback 128 [50%] [-23.88dB] [on]
  Capabilities: pvolume cvolume pswitch pswitch-joined cswitch cswitch-joined cswitch-exclusive
  Limits: Playback 0 - 255 Capture 0 - 128
  Front Left: Playback 0 [0%] [0.00dB] [off] Capture 0 [0%] [-0.18dB] [off]
  Front Right: Playback 0 [0%] [0.00dB] [off] Capture 0 [0%] [-0.18dB] [off]
  Capabilities: pvolume pvolume-joined cvolume cvolume-joined pswitch pswitch-joined cswitch cswitch-joined cswitch-exclusive
  Mono: Playback 0 [0%] [0.00dB] [on] Capture 128 [100%] [23.81dB] [on]
Simple mixer control 'Mic Capture',0
Simple mixer control 'IEC958 In',0
  Capabilities: cswitch cswitch-joined cswitch-exclusive
  Mono: Capture [off]
!!-------Mixer controls for card HD5000
Card hw:4 'HD5000'/'Microsoft Microsoft® LifeCam HD-5000 at usb-0000:03:00.0-10, high speed'
  Components	: 'USB045e:076d'
  Controls      : 4
  Simple ctrls  : 1
  Capabilities: cvolume cvolume-joined cswitch cswitch-joined
  Limits: Capture 0 - 56
  Mono: Capture 42 [75%] [22.00dB] [on]
!!Alsactl output
--startcollapse--
state.DGX {
	control.1 {
		iface MIXER
		name 'Stereo Upmixing'
		value Front Surround
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Front
			item.1 Front Surround
	control.2 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.3 {
		iface PCM
		device 1
		name 'IEC958 Playback Default'
		value '0482000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.4 {
		iface PCM
		device 1
		name 'IEC958 Playback Con Mask'
		value '3eff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.5 {
		iface PCM
		device 1
		name 'IEC958 Playback PCM Stream'
		comment {
			access 'read write inactive'
			type IEC958
			count 1
	control.6 {
		iface PCM
		device 1
		name 'IEC958 Capture Mask'
		value ffffffff00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
		comment {
			access read
			type IEC958
			count 1
	control.7 {
		iface PCM
		device 1
		name 'IEC958 Capture Default'
		value '0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.8 {
		iface MIXER
		name 'IEC958 Loopback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface MIXER
		name 'IEC958 Validity Check Capture Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.10 {
		iface MIXER
		name 'Analog Input Monitor Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.11 {
		iface MIXER
		name 'Analog Input Monitor Playback Volume'
		value 1
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 1'
			dbmin -600
			dbmax 0
			dbvalue.0 0
	control.12 {
		iface MIXER
		name 'Digital Input Monitor Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.13 {
		iface MIXER
		name 'Digital Input Monitor Playback Volume'
		value 1
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 1'
			dbmin -600
			dbmax 0
			dbvalue.0 0
	control.14 {
		iface MIXER
		name 'Analog Output Playback Enum'
		value 'Stereo Headphones'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Stereo Headphones'
			item.1 'Stereo Headphones FP'
			item.2 Multichannel
	control.15 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 213
		value.1 213
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 255'
			dbmin -12550
			dbmax 0
			dbvalue.0 -2068
			dbvalue.1 -2068
	control.16 {
		iface MIXER
		name 'Headphone Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.17 {
		iface MIXER
		name 'Mic Capture Volume'
		value.0 -24
		value.1 -24
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '-24 - 24'
			dbmin -1200
			dbmax 1200
			dbvalue.0 -1200
			dbvalue.1 -1200
	control.18 {
		iface MIXER
		name 'Front Mic Capture Volume'
		value.0 -24
		value.1 -24
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '-24 - 24'
			dbmin -1200
			dbmax 1200
			dbvalue.0 -1200
			dbvalue.1 -1200
	control.19 {
		iface MIXER
		name 'Line Capture Volume'
		value.0 24
		value.1 24
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '-24 - 24'
			dbmin -1200
			dbmax 1200
			dbvalue.0 1200
			dbvalue.1 1200
	control.20 {
		iface MIXER
		name 'Aux Capture Volume'
		value.0 -24
		value.1 -24
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '-24 - 24'
			dbmin -1200
			dbmax 1200
			dbvalue.0 -1200
			dbvalue.1 -1200
	control.21 {
		iface MIXER
		name 'Capture Source'
		value Line
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Mic
			item.1 'Front Mic'
			item.2 Line
			item.3 Aux
	control.22 {
		iface MIXER
		name 'ADC High-pass Filter Capture Enum'
		value Active
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Active
			item.1 Frozen
state.HDMI {
	control.1 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface MIXER
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface MIXER
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.5 {
		iface MIXER
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.7 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.9 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.10 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.11 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.13 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.15 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.16 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.17 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.19 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.25 {
		iface CARD
		name 'HDMI/DP,pcm=10 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.26 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.27 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.28 {
		iface MIXER
		index 4
		comment {
			access 'read write'
			type IEC958
			count 1
	control.29 {
		iface MIXER
		index 4
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.30 {
		iface PCM
		device 10
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.31 {
		iface CARD
		name 'HDMI/DP,pcm=11 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.32 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.33 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.34 {
		iface MIXER
		index 5
		comment {
			access 'read write'
			type IEC958
			count 1
	control.35 {
		iface MIXER
		index 5
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.36 {
		iface PCM
		device 11
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.37 {
		iface PCM
		device 3
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.38 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.39 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.40 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.41 {
		iface PCM
		device 10
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.42 {
		iface PCM
		device 11
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
state.Generic {
	control.1 {
		iface MIXER
		name 'Channel Mode'
		value '2ch'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '2ch'
			item.1 '4ch'
			item.2 '6ch'
	control.2 {
		iface MIXER
		name 'Front Playback Volume'
		value.0 64
		value.1 64
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.3 {
		iface MIXER
		name 'Front Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.4 {
		iface MIXER
		name 'Surround Playback Volume'
		value.0 64
		value.1 64
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.5 {
		iface MIXER
		name 'Surround Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.6 {
		iface MIXER
		name 'Center Playback Volume'
		value 64
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 0
	control.7 {
		iface MIXER
		name 'LFE Playback Volume'
		value 64
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 0
	control.8 {
		iface MIXER
		name 'Center Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface MIXER
		name 'LFE Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.10 {
		iface MIXER
		value.0 64
		value.1 64
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.11 {
		iface MIXER
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.12 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.13 {
		iface MIXER
		name 'Front Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.14 {
		iface MIXER
		name 'Front Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.15 {
		iface MIXER
		name 'Rear Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.16 {
		iface MIXER
		name 'Rear Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.17 {
		iface MIXER
		name 'Line Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.18 {
		iface MIXER
		name 'Line Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.19 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Enabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.20 {
		iface MIXER
		name 'Input Source'
		value 'Front Mic'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Front Mic'
			item.1 'Rear Mic'
			item.2 Line
	control.21 {
		iface MIXER
		name 'Input Source'
		index 1
		value 'Front Mic'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Front Mic'
			item.1 'Rear Mic'
			item.2 Line
	control.22 {
		iface MIXER
		name 'Capture Volume'
		value.0 28
		value.1 28
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 46'
			dbmin -1600
			dbmax 3000
			dbvalue.0 1200
			dbvalue.1 1200
	control.23 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.24 {
		iface MIXER
		index 1
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 46'
			dbmin -1600
			dbmax 3000
			dbvalue.0 -1600
			dbvalue.1 -1600
	control.25 {
		iface MIXER
		index 1
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.26 {
		iface MIXER
		name 'Front Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.27 {
		iface MIXER
		name 'Rear Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.28 {
		iface MIXER
		name 'Line Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.29 {
		iface MIXER
		name 'Master Playback Volume'
		value 44
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 -2000
	control.30 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.31 {
		iface CARD
		name 'Front Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.32 {
		iface CARD
		name 'Rear Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.33 {
		iface CARD
		name 'Line Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.34 {
		iface CARD
		name 'Line Out Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.35 {
		iface CARD
		name 'Front Headphone Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.36 {
		iface PCM
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.37 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.38 {
		iface PCM
		device 2
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.39 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
state.Aureon51MkII {
	control.1 {
		iface PCM
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.2 {
		iface PCM
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.3 {
		iface MIXER
		name 'Mic Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.4 {
		iface MIXER
		name 'Mic Playback Volume'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 255'
			dbmin 0
			dbmax 4781
			dbvalue.0 0
	control.5 {
		iface MIXER
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface MIXER
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 255'
			dbmin 0
			dbmax 4781
			dbvalue.0 0
			dbvalue.1 0
	control.7 {
		iface MIXER
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		value 128
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 255'
			dbmin -4787
			dbmax -6
			dbvalue.0 -2388
	control.9 {
		iface MIXER
		name 'Mic Capture Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.10 {
		iface MIXER
		value 128
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 128'
			dbmin -18
			dbmax 2381
			dbvalue.0 2381
	control.11 {
		iface MIXER
		name 'Mic Capture'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface MIXER
		name 'Line Capture Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.13 {
		iface MIXER
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 128'
			dbmin -18
			dbmax 2381
			dbvalue.0 -18
			dbvalue.1 -18
	control.14 {
		iface MIXER
		name 'IEC958 In Capture Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.15 {
		iface MIXER
		value Mic
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Mic
			item.1 Line
			item.2 'IEC958 In'
	control.16 {
		iface CARD
		name 'Keep Interface'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
state.HD5000 {
	control.1 {
		iface PCM
		value 0
		comment {
			access read
			type INTEGER
			count 1
			range '0 - 36'
	control.2 {
		iface MIXER
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.3 {
		iface MIXER
		value 42
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 56'
			dbmin -2000
			dbmax 3600
			dbvalue.0 2200
	control.4 {
		iface CARD
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
--endcollapse--
!!All Loaded Modules
acpi_cpufreq
aesni_intel
af_alg
agpgart
ahci
algif_hash
algif_skcipher
amdgpu
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccp
cifs
cmac
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dns_resolver
drm
drm_kms_helper
ecc
ecdh_generic
edac_mce_amd
evdev
ext4
fb_sys_fops
fscache
fuse
ghash_clmulni_intel
glue_helper
gpio_amdpt
gpu_sched
hid
hid_generic
hid_logitech_dj
hid_logitech_hidpp
hwmon_vid
i2c_algo_bit
i2c_piix4
input_leds
ip_tables
irqbypass
jbd2
joydev
k10temp
kvm
kvm_amd
ledtrig_audio
libahci
libarc4
libata
libdes
mac_hid
mbcache
mc
md4
mousedev
nct6775
nls_utf8
pcspkr
pinctrl_amd
r8168
rfcomm
rfkill
rng_core
scsi_mod
sd_mod
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_nhlt
snd_mpu401_uart
snd_oxygen
snd_oxygen_lib
snd_pcm
snd_rawmidi
snd_seq_device
snd_timer
snd_usb_audio
snd_usbmidi_lib
soundcore
sp5100_tco
syscopyarea
sysfillrect
sysimgblt
ttm
uas
uinput
usb_storage
usbhid
uvcvideo
vboxdrv
vboxnetadp
vboxnetflt
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x_tables
xhci_hcd
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC1D0/init_pin_configs:
0x03 0x185600f0
0x05 0x185600f0
0x07 0x185600f0
0x09 0x185600f0
0x0b 0x185600f0
0x0d 0x185600f0
0x0f 0x585600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
/sys/class/sound/hwC2D0/init_pin_configs:
0x11 0x40000000
0x12 0x411111f0
0x14 0x01014010
0x15 0x411111f0
0x16 0x411111f0
0x17 0x411111f0
0x18 0x01a19030
0x19 0x02a19040
0x1a 0x0181303f
0x1b 0x02214020
0x1c 0x411111f0
0x1d 0x4024c601
0x1e 0x411111f0
0x1f 0x411111f0
/sys/class/sound/hwC2D0/driver_pin_configs:
/sys/class/sound/hwC2D0/user_pin_configs:
/sys/class/sound/hwC2D0/init_verbs:
/sys/class/sound/hwC2D0/hints:
!!ALSA/HDA dmesg
[    0.140088] ACPI: Added _OSI(Linux-Dell-Video)
[    0.140089] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.140090] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    3.481695] AES CTR mode by8 optimization enabled
[    3.556291] snd_hda_intel 0000:27:00.1: Handle vga_switcheroo audio client
[    3.556295] snd_hda_intel 0000:27:00.1: Force to non-snoop mode
[    3.619279] audit: type=1130 audit(1604305328.755:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.640540] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:27:00.1/sound/card1/input25
[    3.640582] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:27:00.1/sound/card1/input26
[    3.640624] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:27:00.1/sound/card1/input27
[    3.640661] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:27:00.1/sound/card1/input28
[    3.640700] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:27:00.1/sound/card1/input29
[    3.640733] input: HDA ATI HDMI HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:27:00.1/sound/card1/input30
[    3.650853] snd_hda_codec_realtek hdaudioC2D0: autoconfig for ALC892: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    3.650855] snd_hda_codec_realtek hdaudioC2D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.650857] snd_hda_codec_realtek hdaudioC2D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    3.650858] snd_hda_codec_realtek hdaudioC2D0:    mono: mono_out=0x0
[    3.650859] snd_hda_codec_realtek hdaudioC2D0:    inputs:
[    3.650860] snd_hda_codec_realtek hdaudioC2D0:      Front Mic=0x19
[    3.650862] snd_hda_codec_realtek hdaudioC2D0:      Rear Mic=0x18
[    3.650863] snd_hda_codec_realtek hdaudioC2D0:      Line=0x1a
[    3.651228] microcode: CPU1: new patch_level=0x0800820d
[    3.666472] audit: type=1130 audit(1604305328.801:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.697198] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:29:00.3/sound/card2/input31
[    3.697230] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:29:00.3/sound/card2/input32
[    3.697258] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:29:00.3/sound/card2/input33
[    3.697286] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:29:00.3/sound/card2/input34
[    3.697313] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:29:00.3/sound/card2/input35
[    3.931594] [drm] amdgpu kernel modesetting enabled.
[    3.938113] [drm] Connector 1:
[    3.938113] [drm]   HDMI-A-1
[    3.938114] [drm]   HPD4
[    5.077104] NET: Registered protocol family 38
[    5.237260] usbcore: registered new interface driver snd-usb-audio
[    5.341918] amdgpu 0000:27:00.0: fb0: amdgpudrmfb frame buffer device
Like I said, I’m currently on 5.4.72…I’ll switch to 5.8 or 5.9 and report back if the same thing happens again, but it might be a couple of months.
And yeah, I actually just ran a memtest two weeks ago for a different reason (switched to another memory kit), it’s all good. So I’ve had this behavior with two completely different sets of RAM sticks.
That’s fine!
In case you would have to upload a large file that doesn’t fit into an answer or post a screenshot, please read this:
5.8 will go EOL soon, so go for 5.9 straight away.
Let’s wait what Nikgnomic has to say about your alsa output.
All the data from ALSA appears to be problem free
Asus card has the correct driver snd_oxygen
onboard audio and HDMI has snd_hda_intel
and snd_usb_audio for the 2 USB devices
I do not see anything from the original machine check exemption errors relating to audio devices
but you could test if errors relate to the Asus card or USB devices by removing them
Archwiki suggests using package rasdaemon to gather more information
Machine-check exception - ArchWiki
I suggest you look into this possible hardware problem as a priority
undesired or out-of-spec voltages from the power supply
check voltages in BIOS or sensors and try replacing the power supply if possible
