Hello, I want to change the color scheme of my GTK applications, and I only want to change the color scheme not the entire theme. Is this possible?
I am currently using the default theme Adapta-Nokto-Eta-Maia [GTK2/3].
I am using I3wm.
Thanks in advance
Some themes come with different color variants, some do not. You might try this one:
Thanks for the reply, I was just hoping it would be easy to change just the color scheme. But thanks I might want to use that theme!
