The guide on this page does not work
https://wiki.manjaro.org/index.php/Switching_Branches
as the arm-* are not accepted branch names. Should the tool be updated or the guide changed?
There is not written anywhere on that page, that you should use arm-$branch, when using the command on ARM.
You getting to that conclusion, is not the fault of the wiki.
pacman-mirrors will determine the applicable architecture - you don’t specify it.
thanks, it’s too clever
nope - a simple python library call
we used to have a check for i686 but that is years ago
