I need to find The Emacs’s configuration file calledinit.el .
Because I want to set terminal backround instead the Emacs’ default according this
cd /usr/bin/ && ls -l emacs
lrwxrwxrwx 1 root root 10 Ağu 28 21:21 emacs -> emacs-27.1
cd emacs
bash: cd: emacs: Not a directory
cd emacs-27.1
I cant open emacs directory for finding init.el file
How can I open emac directory?
Do I create ? where?
because that is not a directory but a file/a link to a file /usr/bin/emacs is a link to /usr/bin/emacs-27.1
this is the binary, the program itself
Configuration is saved to the file /home/$username/.emacs
much of it can be done from within the program itself
There is also a /home/$username/.emacs.d directory
It does - if you call it with the flag that does this: ls -a
or ls -al
or ls -hl
see man ls
suggestion:
install “mc” - it’s a terminal filemanager
You’ll fast get a grasp of how your system is structured - and it’s an awesome tool
It can be used with a mouse, but it is better when just the keyboard is used (up, down, left, right arrows, the ENTER and the TAB key mostly
But since emacs has the reputation of being the one thing which can do almost everything - file manager and web-browser included - you won’t need it.
