Is there a recommended/optimal way to view the changes between two versions before installing the updates?
I haven’t found a simple way to do that with pacman or pamac and the websites do not show the latest packages.
Btw. is it just me or is the Compare Version feature on the manjaro packages website not working as intended?
It just opens a new tab with the previous website adress with the overview of the searched package.
Those are usually just rebuilds, e.g. in the event that a package they commonly depend on — e.g. glibc — was upgraded and required a recompile of the source code.
I’ll have to leave that for someone else to answer.
Thank you for your quick answer, but two questions remains on this.
So if a package that they commonly depend on was updated, shouldn’t this package also show as an update on my side?
And where can I find the sources of these packages?
For example libva-mesa-driver on the Arch Linux Packages is still on 22.3.4-1 but on the manjaro packages it is 22.3.4-2 but the package source is not listed on the manjaro gitlab page.
Yes, but there’s a chance this was overlooked. Most of the Manjaro developers are currently at FOSDEM in Brussels, and so package updates have been a bit chaotic this weekend.
Some of those packages are automatically rebuilt on a private server run by one of the team members and are then sync’d back to the main repo. You would have to ask them about that.
