I get a systemd-coredump from gnome-keyring-d
System Info:
Kernel: 6.6.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=2858d787-58d2-4b32-bfe2-dcd848223859 rw rootflags=subvol=@
cryptdevice=UUID=ec00de08-393b-4d8c-a1ed-853a4de311ee:cryptroot apparmor=1
security=apparmor udev.log_priority=3 amd_pstate=guided
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5003
date: 10/07/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 31.25 GiB used: 3.9 GiB (12.5%)
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 576 high: 1187 min/max: 550/4673 boost: enabled scaling:
driver: amd-pstate governor: schedutil cores: 1: 550 2: 550 3: 550 4: 550
5: 550 6: 550 7: 550 8: 550 9: 550 10: 550 11: 550 12: 550 13: 550 14: 550
15: 550 16: 1187 17: 550 18: 550 19: 550 20: 550 21: 550 22: 550 23: 550
24: 550 bogomips: 182457
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0b:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.9 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung SyncMaster
serial: <filter> built: 2009 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 587mm (23.1") ratio: 16:9, 15:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.5-1-MANJARO status: kernel-api
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: cryptroot maj-min: 254:0 type: LUKS dm: dm-0 size: 419.26 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:3 size: 419.26 GiB
Local Storage: total: 1.82 TiB used: 143.87 GiB (7.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 39.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 32.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-1: / raw-size: 419.26 GiB size: 419.26 GiB (100.00%)
used: 33.15 GiB (7.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: cryptroot label: N/A uuid: N/A
used: 27.5 MiB (5.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2 label: N/A
uuid: C380-DE14
ID-3: /home raw-size: 419.26 GiB size: 419.26 GiB (100.00%)
ID-4: /run/media/pheiduck/Daten raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 110.69 GiB (11.9%) fs: btrfs dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 3704c1e0-6710-4592-8b0b-28322fd45bbd
ID-1: swap-1 type: zram size: 15.63 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24 dev: /dev/zram0
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 16 MiB fs: <superuser required>
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 418.48 GiB fs: ntfs
label: Windoof uuid: 1E16606116603C41
ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 703 MiB fs: ntfs label: N/A
uuid: FA0453B004536E9F
Device-1: 1-1:2 info: Logitech C922 Pro Stream Webcam type: video,audio
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 5-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 5-3.2:4 info: Metadot Das Keyboard 4 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 24f0:204a class-ID: 0300
Device-2: 5-4:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 31.0 C mobo: 35.0 C gpu: amdgpu temp: 37.0 C
mem: 36.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 523 Uptime: 6m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1350
pm: pacman pkgs: 1340 libs: 371 tools: pamac pm: flatpak pkgs: 10 Shell: Zsh
v: 5.9 running-in: xfce4-terminal inxi: 3.3.31
systemd-coredump:
Dez 10 14:55:33 BlackBox systemd-coredump[1774]: [🡕] Process 1311 (gnome-keyring-d) of user 1000 dumped core.
Stack trace of thread 1311:
#0 0x00007f2c39ac283c n/a (libc.so.6 + 0x8e83c)
#1 0x00007f2c39a72668 raise (libc.so.6 + 0x3e668)
#2 0x00007f2c39a5a4b8 abort (libc.so.6 + 0x264b8)
#3 0x00007f2c39e730ee n/a (libglib-2.0.so.0 + 0x1e0ee)
#4 0x00007f2c39ed41e0 g_assertion_message_expr (libglib-2.0.so.0 + 0x7f1e0)
#5 0x000055d6141f8e08 n/a (gnome-keyring-daemon + 0x27e08)
#6 0x000055d6142759d4 n/a (gnome-keyring-daemon + 0xa49d4)
#7 0x000055d6141f8ecd n/a (gnome-keyring-daemon + 0x27ecd)
#8 0x000055d6141f97ad n/a (gnome-keyring-daemon + 0x287ad)
#9 0x00007f2c398274f6 n/a (libffi.so.8 + 0x74f6)
#10 0x00007f2c39823f5e n/a (libffi.so.8 + 0x3f5e)
#11 0x00007f2c39826b73 ffi_call (libffi.so.8 + 0x6b73)
#12 0x00007f2c39fbb8a4 g_cclosure_marshal_generic (libgobject-2.0.so.0 + 0x1a8a4)
#13 0x00007f2c39fb56c0 g_closure_invoke (libgobject-2.0.so.0 + 0x146c0)
#14 0x00007f2c39fe3a36 n/a (libgobject-2.0.so.0 + 0x42a36)
#15 0x00007f2c39fd1a45 g_signal_emitv (libgobject-2.0.so.0 + 0x30a45)
#16 0x000055d6141fcb2e n/a (gnome-keyring-daemon + 0x2bb2e)
#17 0x00007f2c3a124163 n/a (libgio-2.0.so.0 + 0x121163)
#18 0x00007f2c3a106278 n/a (libgio-2.0.so.0 + 0x103278)
#19 0x00007f2c39eaef69 n/a (libglib-2.0.so.0 + 0x59f69)
#20 0x00007f2c39f0d367 n/a (libglib-2.0.so.0 + 0xb8367)
#21 0x00007f2c39eafb97 g_main_loop_run (libglib-2.0.so.0 + 0x5ab97)
#22 0x000055d6141ef501 n/a (gnome-keyring-daemon + 0x1e501)
#23 0x00007f2c39a5bcd0 n/a (libc.so.6 + 0x27cd0)
#24 0x00007f2c39a5bd8a __libc_start_main (libc.so.6 + 0x27d8a)
#25 0x000055d6141efc45 n/a (gnome-keyring-daemon + 0x1ec45)
Stack trace of thread 1313:
#0 0x00007f2c39b36f6f __poll (libc.so.6 + 0x102f6f)
#1 0x00007f2c39f0d2b6 n/a (libglib-2.0.so.0 + 0xb82b6)
#2 0x00007f2c39ead162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
#3 0x00007f2c39ead1b2 n/a (libglib-2.0.so.0 + 0x581b2)
#4 0x00007f2c39ee0a05 n/a (libglib-2.0.so.0 + 0x8ba05)
#5 0x00007f2c39ac09eb n/a (libc.so.6 + 0x8c9eb)
#6 0x00007f2c39b447cc n/a (libc.so.6 + 0x1107cc)
