I use several disks (internal and usb) containing sensitive data. All disks are encrypted.
When I open a device with cryptsetup
the uncrypted device will be mapped to dev/mapper/some-device
with user and group root
. When I inspect the permissions, I see rwx for all users. Therefore anyone can read my data.
Then I tried to change the permissions, either manually with
sudo chmod 770 some-device
Or via a udev rule:
KERNEL=="dm-*", SUBSYSTEM=="block", ACTION=="add", ENV{DM_NAME}=="some-device", OWNER="me", GROUP="me", MODE="0770"
Both paths do not succeed. The permissions remain always 777
What am I missing here?
This is my system:
~ >>> inxi --admin --verbosity=8 --filter --no-host --width
Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4c2ea2f1-3cfa-4377-8778-97f19f2453fe rw quiet
cryptdevice=UUID=ac37595d-5b67-408c-82b8-547a678e97e6:luks-ac37595d-5b67-408c-82b8-547a678e97e6
root=/dev/mapper/luks-ac37595d-5b67-408c-82b8-547a678e97e6
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop System: MSI product: MS-7798 v: 1.0
serial: <superuser required>
Mobo: MSI model: B75MA-P45 (MS-7798) v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 1.9 date: 09/30/2013
Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device Mouse
status: discharging
System RAM: total: 24 GiB available: 23.4 GiB used: 4.54 GiB (19.4%)
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CML8GX3M2A1600C9 serial: N/A
Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
manufacturer: Hynix/Hyundai part-no: HMT41GU6AFR8A-PB serial: <filter>
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
Info: model: Intel Core i5-3450S bits: 64 type: MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1601 min/max: 1600/2800 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1601 2: 1601 3: 1601 4: 1601 bogomips: 22410
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid xsave
xsaveopt xtopology xtpr
disabled
STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GF108 [GeForce GT 430] driver: nvidia v: 390.157
alternate: nouveau,nvidia_drm non-free: series: 390.xx+
status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie:
gen: 2 speed: 5 GT/s lanes: 16 ports: active: none off: DVI-I-1
empty: HDMI-A-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:0de1 class-ID: 0300
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DVI-I-1 res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: EGL v: 1.5 platforms: gbm: drv: kms_swrast
API: OpenGL v: 4.5 compat-v: 4.6.0 vendor: nvidia mesa v: 390.157
glx-v: 1.4 direct-render: yes renderer: GeForce GT 430/PCIe/SSE2
memory: 1000 MiB
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0bea class-ID: 0403
API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: NetGear WNDA4100 802.11abgn 3x3:3 [Ralink RT3573]
driver: rt2800usb type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-4:4 chip-ID: 0846:9012 class-ID: 0000 serial: <filter>
IF: wlp0s20u4 state: up mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
chip-ID: 0a12:0001 class-ID: e001
Device-1: bitlk_mobi_stick maj-min: 254:3 type: Crypto dm: dm-3
Components:
p-1: sdd1 maj-min: 8:49 size: 119.01 GiB
Device-2: bitlk_daniel_stick maj-min: 254:4 type: Crypto dm: dm-4
Components:
p-1: sdd2 maj-min: 8:50 size: 30 GiB
Device-3: bitlk_bibliothek_stick maj-min: 254:5 type: Crypto dm: dm-5
Components:
p-1: sdd3 maj-min: 8:51 size: 30 GiB
Device-4: bitlk_wiki_stick maj-min: 254:6 type: Crypto dm: dm-6
Components:
p-1: sdd4 maj-min: 8:52 size: 30 GiB
Device-5: luks-ac37595d-5b67-408c-82b8-547a678e97e6 maj-min: 254:0
type: LUKS dm: dm-0 size: 232.59 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 232.59 GiB
Device-6: luks-aa7c5077-2732-494c-8f37-9d6d9852f1d5 maj-min: 254:1
type: LUKS dm: dm-1 size: 465.76 GiB
Components:
p-1: sdb1 maj-min: 8:17 size: 465.76 GiB
Device-7: luks-97478fb5-267e-493d-8774-49eef2f55050 maj-min: 254:2
type: LUKS dm: dm-2 size: 465.76 GiB
Components:
p-1: sdc1 maj-min: 8:33 size: 465.76 GiB
Local Storage: total: 1.37 TiB used: 858.35 GiB (61.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000AZRX-00A8LB0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1A01
scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: Flash Drive FIT
size: 239.02 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1100 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NS90 rev: IN01
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 94.61 GiB (41.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ac37595d-5b67-408c-82b8-547a678e97e6 label: System
uuid: 4c2ea2f1-3cfa-4377-8778-97f19f2453fe
used: 472 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 04E7-F02F
ID-3: /run/media/schatzi/Bibliothek raw-size: 30 GiB size: 30 GiB (100.00%)
used: 8.32 GiB (27.7%) fs: fuseblk dev: /dev/dm-5 maj-min: 254:5
mapped: bitlk_bibliothek_stick label: N/A uuid: N/A
ID-4: /run/media/schatzi/Daniel raw-size: 30 GiB size: 30 GiB (100.00%)
used: 15.5 GiB (51.7%) fs: fuseblk dev: /dev/dm-4 maj-min: 254:4
mapped: bitlk_daniel_stick label: N/A uuid: N/A
ID-5: /run/media/schatzi/Data raw-size: 465.76 GiB
size: 457.38 GiB (98.20%) used: 382.84 GiB (83.7%) fs: ext4 dev: /dev/dm-2
maj-min: 254:2 mapped: luks-97478fb5-267e-493d-8774-49eef2f55050
label: Data uuid: aea89950-6192-4055-8c45-0991f2477684
ID-6: /run/media/schatzi/Extra raw-size: 465.76 GiB
size: 457.38 GiB (98.20%) used: 316.99 GiB (69.3%) fs: ext4 dev: /dev/dm-1
maj-min: 254:1 mapped: luks-aa7c5077-2732-494c-8f37-9d6d9852f1d5
label: Extra uuid: 61a2cc0c-2b1f-46e2-a956-a42b5e447f2a
ID-7: /run/media/schatzi/Mobi raw-size: 119.01 GiB
size: 119.01 GiB (100.00%) used: 34.44 GiB (28.9%) fs: fuseblk dev: /dev/dm-3
maj-min: 254:3 mapped: bitlk_mobi_stick label: N/A uuid: N/A
ID-8: /run/media/schatzi/Wiki raw-size: 30 GiB size: 30 GiB (100.00%)
used: 5.65 GiB (18.8%) fs: fuseblk dev: /dev/dm-6 maj-min: 254:6
mapped: bitlk_wiki_stick label: N/A uuid: N/A
ID-1: swap-1 type: file size: 8 GiB used: 256 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdd1 maj-min: 8:49 size: 119.01 GiB fs: bitlocker label: N/A
uuid: N/A
ID-2: /dev/sdd2 maj-min: 8:50 size: 30 GiB fs: bitlocker label: N/A
uuid: N/A
ID-3: /dev/sdd3 maj-min: 8:51 size: 30 GiB fs: bitlocker label: N/A
uuid: N/A
ID-4: /dev/sdd4 maj-min: 8:52 size: 30 GiB fs: bitlocker label: N/A
uuid: N/A
ID-5: /dev/sdd5 maj-min: 8:53 size: 30 GiB fs: bitlocker label: N/A
uuid: N/A
Device-1: 1-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 1-3:3 info: Realtek 4-Port USB 2.0 Hub ports: 2 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5412
Device-1: 1-4:4 info: NetGear WNDA4100 802.11abgn 3x3:3 [Ralink RT3573]
type: Network driver: rt2800usb interfaces: 1 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 450mA
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
Hub-4: 2-3:2 info: Realtek 4-Port USB 3.0 Hub ports: 2 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0412
Device-1: 2-3.1:3 info: Silicon Motion - Taiwan (formerly Feiya ) Flash
Drive type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 304mA
chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-6: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Hub-7: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-8: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-9: 4-1.5:3 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
chip-ID: 214b:7250 class-ID: 0900
Hub-10: 4-1.5.3:4 info: Monterey BakkerElkhuizen Wired Keyboard S-board
840 Design USB-Hub ports: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 0566:3020 class-ID: 0900
Device-1: 4-1.5.3.2:5 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Device-2: 4-1.5.3.3:6 info: Monterey BakkerElkhuizen Wired Keyboard
S-board 840 Design type: keyboard,HID driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
power: 100mA chip-ID: 0566:3013 class-ID: 0300
System Temperatures: cpu: 36.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1789 libs: 442 tools: pamac pm: flatpak pkgs: 0
1: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
2: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
3: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
4: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
5: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
6: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
7: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
8: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 330
1: cpu: 12.7% command: python pid: 13785 mem: 42.1 MiB (0.1%)
2: cpu: 7.4% command: rsync pid: 13915 mem: 41.5 MiB (0.1%)
3: cpu: 7.3% command: firefox pid: 1461 mem: 782.6 MiB (3.2%)
4: cpu: 7.2% command: firefox pid: 7866 mem: 526.2 MiB (2.1%)
5: cpu: 3.9% command: Xorg pid: 810 mem: 142.4 MiB (0.5%)
Memory top: 5 of 330
1: mem: 782.6 MiB (3.2%) command: firefox pid: 1461 cpu: 7.3%
2: mem: 576.2 MiB (2.4%) command: plasmashell pid: 995 cpu: 0.4%
3: mem: 526.2 MiB (2.1%) command: firefox pid: 7866 cpu: 7.2%
4: mem: 378.8 MiB (1.5%) command: firefox pid: 4415 cpu: 1.0%
5: mem: 347.6 MiB (1.4%) command: firefox pid: 7988 cpu: 2.3%
Processes: 330 Power: uptime: 2h 23m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.33 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
