What can I do about this error?
The following package cannot be upgraded due to unresolvable dependencies:
warning: cannot resolve “nvidia-utils=510.54”, a dependency of “linux517-nvidia”
What are you trying to do, where does this message come from, and can you post the whole terminal output?
The following packages will be installed:
linux517
linux517-virtualbox-host-modules
linux517-nvidia
Starting
resolving dependencies…
:: The following package cannot be upgraded due to unresolvable dependencies:
linux517-nvidia
:: Do you want to skip the above package for this upgrade? [y/N]
:: unable to satisfy dependency ‘nvidia-utils=510.54’ required by linux517-nvidia
Done …
Hello,
You use unstable branch, and simply the nvidia module for linux5.17 was not build yet. This things can happen.
Now you should be able yo install it
sudo mhwd-kernel -i linux517
And should install, if not, try manually to install the module
sudo pacman-mirrors -f5 && sudo pacman -Syyu linux517-nvidia
Then boot normally in 5.17 kernel.
Problem solved. Thanks so much!
