gage
10 March 2023 00:39
1
I have an NVIDIA 960 and have been trying to install Manjaro 6.1.12 on my computer with proprietary drivers. Unfortunately when I boot from USB with proprietary drivers all I see is “Input not supported” on my monitor. This also occurred after I tried to install proprietary drivers on a installation with open source ones and restarted the system. Huge bummer since I want to play games on this computer. Any advice you could offer is appreciated. Im very new to linux, so I may need more explanation than other folks on this forum.
Again, Thank you
Hello @gage
What version? What is the exact model?
Please open terminal and enter:
inxi -v7az
That will print detailed system information.
Please don’t send pictures, instead copy and paste the output here as code. Markdown is supported
Also, this should be useful:
mhwd -l
mhwd -li
gage
10 March 2023 01:40
3
hey @megavolt , thank you for your reply. Here is the information from the inxi command
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=db1347e3-f110-4776-a425-dae9e0192e3b rw quiet splash
resume=UUID=c5494d64-bf36-4c2e-acfb-981e2c0da07a udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: MSI product: MS-7823 v: 1.0
serial: <superuser required>
Mobo: MSI model: CSM-H87M-G43 (MS-7823) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.4
date: 09/23/2013
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/M235
status: discharging
RAM: total: 13.59 GiB used: 4.24 GiB (31.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-4770 bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1834 high: 3900 min/max: 800/3900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 857 3: 1080
4: 800 5: 1409 6: 3900 7: 1933 8: 3900 bogomips: 54420
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: eVga.com. driver: nouveau
v: kernel non-free: 525.xx+ status: current (as of 2023-02) arch: Maxwell
code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1
empty: DP-1, DP-2, DP-3, DVI-I-1 bus-ID: 01:00.0 chip-ID: 10de:1401
class-ID: 0300 temp: 26.0 C
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer K273 serial: <filter>
built: 2022 res: 1920x1080 hz: 75 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.3 Mesa 22.3.5 renderer: NV126 direct-render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fba
class-ID: 0403
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Local Storage: total: 728.46 GiB used: 78.05 GiB (10.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000AAKX-60U6AA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1H18 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Glide
size: 29.82 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.27 scheme: MBR
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24F1ST a rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 217.64 GiB size: 213.17 GiB (97.94%)
used: 78.05 GiB (36.6%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: db1347e3-f110-4776-a425-dae9e0192e3b
used: 312 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 152D-E28E
ID-1: swap-1 type: partition size: 14.94 GiB used: 512 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: c5494d64-bf36-4c2e-acfb-981e2c0da07a
ID-1: /dev/sda1 maj-min: 8:1 size: 465.76 GiB fs: ntfs label: New Volume
uuid: 94E63CE8E63CCBEC
ID-2: /dev/sdc1 maj-min: 8:33 size: 3.31 GiB fs: iso9660
ID-3: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 7CFD-039F
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-6: 3-3:3 info: Dell Keyboard Hub ports: 3 rev: 1.1 speed: 12 Mb/s
power: 50mA chip-ID: 413c:1001 class-ID: 0900
Device-1: 3-3.1:5 info: Dell Keyboard HID Support type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 413c:2001 class-ID: 0300
Device-2: 3-11:4 info: SanDisk Cruzer Glide type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5575 class-ID: 0806 serial: <filter>
Hub-7: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 92.0 C mobo: N/A gpu: nouveau temp: 26.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 661
Processes: 255 Uptime: 1h 14m wakeups: 6 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1090 libs: 331 tools: pamac Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
mhwd -li
gives
NAME VERSION FREEDRIVER TYPE
mhwd -l
gives
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
@gage So actually you are running the nouveau driver. , but nvidia driver is installed, but not loaded. I guess you just installed the driver with the package manager and not with mhwd?
Did you follow this guide, or how did you install it?
gage
10 March 2023 01:47
5
While trouble shooting this i installed a package called nvidia-utils
. would that have installed it?
gage
10 March 2023 01:55
6
is there a specific one is should be loading into and how would I do that?
Mhwd can autodetect the gpu and install the correct driver:
sudo mhwd -a pci nonfree 0300
It also does all basic configurations for the nvidia driver.
gage
10 March 2023 02:01
8
Last time I ran that command and restarted my pc it said “input not supported”. I shoulve specified thats how i installed it thats my bad.
I guess the resolution which was detected by the nvidia driver was not supported by the monitor, therefore the monitor reports “Input not supported”.
Maybe try the 470xx driver instead:
sudo mhwd -i video-nvidia-470xx
before fiddling with custom EDID’s.
gage
10 March 2023 02:26
10
After a restart it still is using open source drivers. mhwd -li
shoes both video-linux
and video-nvida-470xx
. inxi
gives
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: eVga.com. driver: nvidia
v: 470.161.03 alternate: nouveau,nvidia_drm non-free: 525.xx+
It seems like the proprietary driver isn’t working and its going to the backup?
Before:
After:
Do you see the difference? Actually, you are running the NVIDIA driver now.
gage
10 March 2023 02:39
12
Dang, the game im trying to play isn’t working even with the nvidia driver then. When i launch the game it says A D3D11-compatible GPU (Feature level 11.0, Shader Model 5.0) is required to run the engine.
which is weird because this game worked on windows and should work with proton.
Vulkan is needed for DXVK.
Test if vulkan is working:
pamac install vulkan-tools
vulkaninfo --summary
vkcube
Probably you need to add this to the startup options:
VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/nvidia_icd.json %command%
gage
10 March 2023 03:07
14
Vulkan-info --summary
gives
Instance Extensions: count = 20
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_portability_enumeration : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Instance Layers: count = 5
VK_LAYER_NV_optimus NVIDIA Optimus layer 1.2.175 version 1
VK_LAYER_VALVE_steam_fossilize_32 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_fossilize_64 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_32 Steam Overlay Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_64 Steam Overlay Layer 1.3.207 version 1
Devices:
GPU0:
apiVersion = 1.2.175
driverVersion = 470.161.3.192
vendorID = 0x10de
deviceID = 0x1401
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = NVIDIA GeForce GTX 960
driverID = DRIVER_ID_NVIDIA_PROPRIETARY
driverName = NVIDIA
driverInfo = 470.161.03
conformanceVersion = 1.2.6.0
deviceUUID = 1fdb99f3-5271-a6f9-230c-090b18d529f4
driverUUID = 21235eef-a066-1931-6351-fce5f4c8e266
and vkcube
causes some windows to do a waterfall effect when i move them.
I am not sure what you mean by startup options.
No idea.
You said, you use proton, therefore I assume you use steam and steam has startup options, game launch options or however it is called.
gage
10 March 2023 03:16
16
unfortunately putting that in the options did not help.
Vulkan works on your system beside this “water fall” effect (what ever that is). It must be then clearly a steam or proton issue. But that is not the topic of this thread. I guess the main problem is solved now?
Feel free to create another topic about steam and the game.
Don’t forget to mark the post which solved your problem as Solution
system
Closed
12 March 2023 21:33
18
