Change default terminal for Nautilus "open in terminal"
Hi,
I am using alacritty as my main terminal and have already set up keyboard shortcuts to open it instead of gnome-terminal.
In addition to this Id like to have it open from nautilus as well when right-clicking and selecting Open in Terminal.
All I found so far are old hacks for Ubuntu 13.04.
Does anyone have an idea how to achieve this in Manjaro cleanly (without symlinking /usr/bin/alacritty to /usr/bin/gnome-terminal) ?
Install and open dconf-editor, navigate to /org/gnome/desktop/applications/terminal, edit exec to suit.
Thanks for the quick response. Ive tried it, but in dconf-editor it says DEPRECATED: This key is deprecated and ignored. The default terminal is handled in GIO.
From what I see GIO is a library though. Any idea if it respects environment variables?
Ill do some more digging myself here.
I did a web search for "arch gnome default terminal" and found this:
So there you go. :man_shrugging:
Thank you!
Here is the solution that made it work for me:
  • (optional) Remove gnome-terminal
  • install python-nautilus
    Created this script and put into ~/.local/share/nautilus-python/extensions/open-alacritty.py:
import os
from gi.repository import Nautilus, GObject
class ColumnExtension(GObject.GObject, Nautilus.MenuProvider):
    def __init__(self):
        pass
    def menu_activate_cb(self, menu, file):
        os.system("/usr/bin/alacritty --working-directory " + file.get_location().get_path())
    def get_background_items(self, window, file):
        item = Nautilus.MenuItem(name='NautilusOpenAlacritty',
                                         label='Open in Alacritty',
                                         tip='',
                                         icon='')
        item.connect('activate', self.menu_activate_cb, file)
        return item,
