is there a possibility to change the default calendar for incoming invitations?
I would like to use my google calendar by default. Current it’s always the native calendar of Evolution. So I have to change on each invitation mail.
Thanks for the link. Unfortunately not what I’m looking for. I didn’t find anything to change the default calendar for invitations.
Found it.
Menu “Edit / Accounts” --> select calendar you wish and click “Edit” --> here’s a property to mark calendar as default.
