Change application launcher order on search?
I have both Kcalc & “LibreOffice Calc” installed on my system. When I press the windows-key to open the launcher and enter “calc” I want “LibreOffice Calc” to be the top result instead of “Kcalc”. Is this possible and if so what do I need to do to achieve that?
I think you only need to set Libre Calc as a favorite. And when you press the Windows button, the application launcher menu opens and displays your favorites on the side?
Correct - setting Libreoffic-Calc as a favorite will ensure it is returned above kcalc.
(of course assuming kcalc is not a favorite as well)
