Chane right click behavior on Macbook Pro
Hi,
so after running Gentoo Linux with i3 for a while and not using the touchpad i decided to go back to Manjaro because mainting Gentoo when not used daily is time consuming.
Installation and everything else went fine, but i have only 1 problem: The default settings for right click is on 2 finger tap. I always and ever used the bottom right corner for right click and i didn’t found any setting or driver that could change that with a gui. How can i change the right click to the bottom right area of my touchpad?
I have a MacbookPro6,2 with multitouch
