I’m trying to install hisa and cfmesh-of on my machine in order to use the cfd-of workbench in FreeCAD as a frontend for OpenFOAM (org).
Allwmake script seems to run into problems building cfmesh-of from source.
My inxi -Fazy output
Kernel: 5.11.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=cbeb8c53-a621-42ac-a96b-0b748f010d08 ro i915.modeset=1
init=/usr/bin/e4rat-lite-preload intel_pstate=enable quiet apparmor=1
security=apparmor resume=UUID=6315efe9-3ada-4d9e-973b-87e77635e076
udev.log_priority=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: TOSHIBA product: SATELLITE L855 v: PSKA8E-006008N5
serial:
Mobo: TOSHIBA model: Portable PC v: MP serial:
UEFI-[Legacy]: Insyde v: 1.60 date: 04/20/2012
ID-1: BAT0 charge: 39.8 Wh (100.0%) condition: 39.8/48.6 Wh (81.9%)
volts: 10.8 min: 10.8 model: PA5024U-1BRS type: Li-ion serial:
status: Full
Info: Quad Core model: Intel Core i7-3610QM bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36732
Speed: 2062 MHz min/max: 1200/2300 MHz Core speeds (MHz): 1: 2062 2: 2181
3: 2203 4: 2255 5: 2028 6: 2295 7: 2295 8: 2136
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Toshiba driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Importek TOSHIBA Web Camera - HD type: USB driver: uvcvideo
bus-ID: 1-1.3:5 chip-ID: 10f1:1a43 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 99 size: 350x190mm (13.8x7.5")
diag: 398mm (15.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Toshiba
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.11.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Toshiba
driver: alx v: kernel port: 2000 bus-ID: 01:00.0 chip-ID: 1969:1091
class-ID: 0200
IF: enp1s0 state: down mac:
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Askey
driver: ath9k v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 168c:0032
class-ID: 0280
IF: wlp2s0 state: up mac:
IF-ID-1: virbr0 state: down mac:
Device-1: Toshiba Bluetooth USB Host Controller type: USB driver: btusb
v: 0.8 bus-ID: 1-1.2:13 chip-ID: 0930:0219 class-ID: e001 serial:
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Local Storage: total: 465.76 GiB used: 129.12 GiB (27.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK5075GSX
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: rev: 1M scheme: MBR
ID-1: / raw-size: 448.64 GiB size: 440.59 GiB (98.21%)
used: 129.12 GiB (29.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 200 (default 60) cache-pressure: 10 (default 100)
ID-1: swap-1 type: zram size: 6 GiB used: 1.01 GiB (16.9%) priority: -2
dev: /dev/zram0
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 272 Uptime: 1d 3h 05m wakeups: 27 Memory: 15.56 GiB
used: 2.79 GiB (17.9%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: 1767 pacman: 1752 lib: 456 flatpak: 15
Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04 ```
terminal output of ./Allwmake executed from /opt/OpenFOAM/ThirdParty-8 (containing only files from cfmesh-of)
wmake error: could not change to directory 'meshLibrary'
wmake executables
wmake cartesian2DMesh
make[1]: Entering directory '/opt/OpenFOAM/ThirdParty-8/executables/cartesian2DMesh'
Making dependency list for source file cartesian2DMesh.C
could not open file cartesian2DMeshGenerator.H for source file cartesian2DMesh.C due to No such file or directory
could not open dependencies file Make/linux64GccDPInt32Opt/cartesian2DMesh.C.dep for source file cartesian2DMesh.C due to Permission denied
make[1]: *** No rule to make target 'Make/linux64GccDPInt32Opt/cartesian2DMesh.C.dep', needed by 'Make/linux64GccDPInt32Opt/cartesian2DMesh.o'. Stop.
make[1]: Leaving directory '/opt/OpenFOAM/ThirdParty-8/executables/cartesian2DMesh'
make: *** [/opt/OpenFOAM/OpenFOAM-8/wmake/makefiles/apps:39: cartesian2DMesh] Error 2
wmake utilities .
wmake executables
wmake utilities .
wmake executables
wmake utilities .
./Allwmake executed as sudo, got this error:
cd /opt/OpenFOAM/ThirdParty-8/ && sudo ./Allwmake
wmake error: environment variable $WM_OPTIONS not set
so i checked /opt/OpenFOAM/OpenFOAM-8/etc/config.sh/settings
and don’t understand if something is wrong:
settings
#----------------------------------*-sh-*--------------------------------------
# \\ / F ield | OpenFOAM: The Open Source CFD Toolbox
# \\ / O peration | Website: https://openfoam.org
# \\ / A nd | Copyright (C) 2011-2020 OpenFOAM Foundation
# \\/ M anipulation |
# License
# This file is part of OpenFOAM.
# OpenFOAM is free software: you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
# for more details.
# You should have received a copy of the GNU General Public License
# along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>.
# File
# etc/config.sh/settings
# Description
# Startup file for OpenFOAM
# Sourced from OpenFOAM-<VERSION>/etc/bashrc
# Set environment variables according to system type
export WM_ARCH=`uname -s`
case "$WM_ARCH" in
Linux)
WM_ARCH=linux
# Compiler specifics
case `uname -m` in
i686)
export WM_ARCH_OPTION=32
export WM_CC='gcc'
export WM_CXX='g++'
export WM_CFLAGS='-fPIC'
export WM_CXXFLAGS='-fPIC -std=c++0x'
export WM_LDFLAGS=
x86_64)
case "$WM_ARCH_OPTION" in
32)
export WM_COMPILER_ARCH=64
export WM_CC='gcc'
export WM_CXX='g++'
export WM_CFLAGS='-m32 -fPIC'
export WM_CXXFLAGS='-m32 -fPIC -std=c++0x'
export WM_LDFLAGS='-m32'
64)
WM_ARCH=linux64
export WM_COMPILER_LIB_ARCH=64
export WM_CC='gcc'
export WM_CXX='g++'
export WM_CFLAGS='-m64 -fPIC'
export WM_CXXFLAGS='-m64 -fPIC -std=c++0x'
export WM_LDFLAGS='-m64'
echo "Unknown WM_ARCH_OPTION '$WM_ARCH_OPTION', should be 32 or 64"\
1>&2
esac
aarch64)
WM_ARCH=linuxArm64
export WM_CC='gcc'
export WM_CXX='g++'
export WM_LDFLAGS=
armv7l)
WM_ARCH=linuxARM7
export WM_COMPILER_LIB_ARCH=32
export WM_CC='gcc'
export WM_CXX='g++'
export WM_LDFLAGS=
ppc64)
WM_ARCH=linuxPPC64
export WM_CC='gcc'
export WM_CXX='g++'
ppc64le)
WM_ARCH=linuxPPC64le
export WM_CC='gcc'
export WM_CXX='g++'
echo Unknown processor type `uname -m` for Linux 1>&2
esac
SunOS)
WM_ARCH=SunOS64
WM_MPLIB=FJMPI
export WM_CC='gcc'
export WM_CXX='g++'
export WM_CFLAGS='-mabi=64 -fPIC'
export WM_CXXFLAGS='-mabi=64 -fPIC -std=c++0x'
export WM_LDFLAGS='-mabi=64 -G0'
*) # An unsupported operating system
/bin/cat <<USAGE 1>&2
Your "$WM_ARCH" operating system is not supported by this release
of OpenFOAM. For further assistance, please contact https://openfoam.org
USAGE
esac
# Location of the jobControl directory
export FOAM_JOB_DIR=$WM_PROJECT_INST_DIR/jobControl
# wmake configuration
export WM_DIR=$WM_PROJECT_DIR/wmake
export WM_LINK_LANGUAGE=c++
export WM_LABEL_OPTION=Int$WM_LABEL_SIZE
export WM_OPTIONS=$WM_ARCH$WM_COMPILER$WM_PRECISION_OPTION$WM_LABEL_OPTION$WM_COMPILE_OPTION
# Base executables/libraries
export FOAM_APPBIN=$WM_PROJECT_DIR/platforms/$WM_OPTIONS/bin
export FOAM_LIBBIN=$WM_PROJECT_DIR/platforms/$WM_OPTIONS/lib
# External (ThirdParty) libraries
export FOAM_EXT_LIBBIN=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER$WM_PRECISION_OPTION$WM_LABEL_OPTION/lib
# Site-specific directory
siteDir="${WM_PROJECT_SITE:-$WM_PROJECT_INST_DIR/site}"
# Shared site executables/libraries
# Similar naming convention as ~OpenFOAM expansion
export FOAM_SITE_APPBIN=$siteDir/$WM_PROJECT_VERSION/platforms/$WM_OPTIONS/bin
export FOAM_SITE_LIBBIN=$siteDir/$WM_PROJECT_VERSION/platforms/$WM_OPTIONS/lib
# User executables/libraries
export FOAM_USER_APPBIN=$WM_PROJECT_USER_DIR/platforms/$WM_OPTIONS/bin
export FOAM_USER_LIBBIN=$WM_PROJECT_USER_DIR/platforms/$WM_OPTIONS/lib
# DynamicCode templates
# - default location is the "~OpenFOAM/codeTemplates/dynamicCode" expansion
# export FOAM_CODE_TEMPLATES=$WM_PROJECT_DIR/etc/codeTemplates/dynamicCode
# Convenience
export FOAM_ETC=$WM_PROJECT_DIR/etc
export FOAM_APP=$WM_PROJECT_DIR/applications
export FOAM_SRC=$WM_PROJECT_DIR/src
export FOAM_TUTORIALS=$WM_PROJECT_DIR/tutorials
export FOAM_UTILITIES=$FOAM_APP/utilities
export FOAM_SOLVERS=$FOAM_APP/solvers
export FOAM_RUN=$WM_PROJECT_USER_DIR/run
# Add wmake to the path - not required for runtime-only environment
[ -d "$WM_DIR" ] && PATH=$WM_DIR:$PATH
# Add OpenFOAM scripts to the path
export PATH=$WM_PROJECT_DIR/bin:$PATH
# Add site-specific scripts to path - only if they exist
if [ -d "$siteDir/bin" ] # Generic
then
_foamAddPath "$siteDir/bin"
fi
if [ -d "$siteDir/$WM_PROJECT_VERSION/bin" ] # Version-specific
then
_foamAddPath "$siteDir/$WM_PROJECT_VERSION/bin"
fi
unset siteDir
_foamAddPath $FOAM_USER_APPBIN:$FOAM_SITE_APPBIN:$FOAM_APPBIN
# Make sure to pick up dummy versions of external libraries last
_foamAddLib $FOAM_USER_LIBBIN:$FOAM_SITE_LIBBIN:$FOAM_LIBBIN:$FOAM_EXT_LIBBIN:$FOAM_LIBBIN/dummy
# Compiler settings
unset gcc_version gmp_version mpfr_version mpc_version
unset MPFR_ARCH_PATH GMP_ARCH_PATH
# Location of compiler installation
if [ -z "$WM_COMPILER_TYPE" ]
then
WM_COMPILER_TYPE=system
echo "Warning in $WM_PROJECT_DIR/etc/config.sh/settings:" 1>&2
echo " WM_COMPILER_TYPE not set, using '$WM_COMPILER_TYPE'" 1>&2
fi
# Load configured compiler versions, regardless of the compiler type
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config.sh/compiler`
case "$WM_COMPILER_TYPE" in
OpenFOAM | ThirdParty)
if [ -n "$gcc_version" ]
then
gccDir=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/$gcc_version
gmpDir=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/$gmp_version
mpfrDir=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/$mpfr_version
mpcDir=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/$mpc_version
# Check that the compiler directory can be found
[ -d "$gccDir" ] || {
echo 1>&2
echo " Cannot find $gccDir installation." 1>&2
echo " Please install this compiler version or if you wish to" \
" use the system compiler," 1>&2
echo " change the 'WM_COMPILER_TYPE' setting to 'system'" 1>&2
echo
_foamAddMan $gccDir/man
_foamAddPath $gccDir/bin
# Add compiler libraries to run-time environment
_foamAddLib $gccDir/lib$WM_COMPILER_LIB_ARCH
# Add gmp/mpfr libraries to run-time environment
_foamAddLib $gmpDir/lib$WM_COMPILER_LIB_ARCH
_foamAddLib $mpfrDir/lib$WM_COMPILER_LIB_ARCH
# Add mpc libraries (not need for older gcc) to run-time environment
if [ -n "$mpc_version" ]
then
_foamAddLib $mpcDir/lib$WM_COMPILER_LIB_ARCH
fi
# Used by boost/CGAL:
export MPFR_ARCH_PATH=$mpfrDir
export GMP_ARCH_PATH=$gmpDir
fi
unset gcc_version gccDir
unset gmp_version gmpDir mpfr_version mpfrDir mpc_version mpcDir
if [ -n "$clang_version" ]
then
clangDir=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/$clang_version
[ -d "$clangDir" ] || {
echo 1>&2
echo " Cannot find $clangDir installation." 1>&2
echo 1>&2
_foamAddMan $clangDir/share/man
_foamAddPath $clangDir/bin
fi
unset clang_version clangDir
system)
# Use system compiler
echo "Warn: WM_COMPILER_TYPE='$WM_COMPILER_TYPE' is unsupported" 1>&2
echo " treating as 'system' instead" 1>&2
esac
installed version of openfoam:
pacman -Qs Openfoam
local/openfoam 8-1
cfmesh-of downloaded from https://sourceforge .net/projects/cfmesh-cfdof/
Please let me know if I should provide more information.
