Certain apps run at 60fps on my 165Hz monitor while using both screens
Hello, I have been a Manjaro user for half a year now and I love it thus far, but I have an issue where if I use both my ThinkPad’s built in screen (1080p 60hz) and my LG UltraGear external monitor (2K 165hz), certain applications will keep running at 60fps even when displayed on my higher refresh monitor, this happens with Discord, Cider and another bunch but these are the main ones, it’s blatantly obvious when I scroll that they run at 60hz, this does not happen when I use my LG monitor alone and disable the built in screen. It also happens in both Wayland and X11, any clues?
[aleck@e14 ~]$ inxi -Fazy
  Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=f7c94276-524c-46cc-8f72-d6bc3154d42c rw quiet splash apparmor=1
  Desktop: GNOME v: 46.2 tk: GTK v: 3.24.42 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 21JSS0Y500 v: ThinkPad E14 Gen 5
  Mobo: LENOVO model: 21JSS0Y500 v: ThinkPad serial: <superuser required>
    part-nu: LENOVO_MT_21JS_BU_Think_FM_ThinkPad E14 Gen 5
    uuid: <superuser required> UEFI: LENOVO v: R2CET29W (1.11 )
    date: 07/25/2023
  ID-1: BAT0 charge: 46.2 Wh (99.8%) condition: 46.3/47.0 Wh (98.5%)
    volts: 12.9 min: 11.3 model: Sunwoda L22D3PG4 type: Li-poly serial: <filter>
    status: not charging cycles: 37
  Info: model: AMD Ryzen 7 7730U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000D
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 3358 high: 4346 min/max: 400/4546 scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3347 2: 4346 3: 2603
    4: 3392 5: 2461 6: 3573 7: 3256 8: 3534 9: 3254 10: 4106 11: 2473 12: 3606
    13: 3062 14: 3596 15: 2923 16: 4196 bogomips: 63897
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-2,eDP-1
    empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7 class-ID: 0300
    temp: 66.0 C
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 174f:2469
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
    s-diag: 1245mm (49.01")
  Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,top-right
    model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2023 res: 2560x1440
    hz: 165 dpi: 108 gamma: 1.2 size: 600x340mm (23.62x13.39")
    diag: 690mm (27.2") ratio: 16:9 modes: max: 2560x1440 min: 640x480
  Monitor-2: eDP-1 mapped: eDP pos: bottom-l model: AU Optronics 0xfa9b
    built: 2021 res: 1920x1200 hz: 60 dpi: 162 gamma: 1.2
    size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10 modes:
    max: 1920x1200 min: 640x480
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    LLVM 17.0.6 DRM 3.57 6.9.3-3-MANJARO) device-ID: 1002:15e7 memory: 1000 MiB
    unified: no
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.9-manjaro1.1
    device-ID: 1002:15e7 surfaces: xcb,xlib
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: DCMT USB Condenser Microphone
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-1.4.2.2:9 chip-ID: 31b2:0011 class-ID: 0300
    serial: <filter>
  Device-5: Lenovo ThinkPad Dock Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-1.4.2.3:10 chip-ID: 17ef:3063 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: r8168 v: 8.053.00-NAPI modules: r8169 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp2s0 state: down mac: <filter>
  Device-3: Lenovo ThinkPad Dock Ethernet [Realtek RTL8153B] driver: r8152
    type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.1:3
    chip-ID: 17ef:3062 class-ID: 0000 serial: <filter>
  IF: enp4s0f3u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Info: services: httpd, NetworkManager, proftpd, systemd-timesyncd,
    wpa_supplicant
  Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
    driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 3-4:3 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
  Local Storage: total: 1.82 TiB used: 475.45 GiB (25.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02106 temp: 49.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SDRW-11A0XS0
    size: 931.48 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter> fw-rev: 1034 scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 321.45 GiB (35.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 78.0 C mobo: 46.0 C gpu: amdgpu temp: 66.0 C
  Fan Speeds (rpm): fan-1: 3100 fan-2: 3100
  Memory: total: 16 GiB note: est. available: 14.46 GiB used: 10.8 GiB (74.7%)
  Processes: 432 Power: uptime: 9h 57m states: freeze,mem,disk
    suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 5.77 GiB services: gsd-power,
    tool: systemctl
  Packages: 1670 pm: pacman pkgs: 1604 libs: 508 tools: gnome-software,pamac
    pm: flatpak pkgs: 66 Compilers: gcc: 14.1.1 Shell: Bash v: 5.2.26
    running-in: gnome-terminal inxi: 3.3.35
[aleck@e14 ~]$
Probably switch to Wayland, since it has better support for mixed refresh rates. Xorg is no longer being developed, but just maintained.
It happens in both Wayland and X11 as mentioned previously, maybe there’s some settings I have to tweak there? I’m not sure how I could fix this, thanks
Well it for sure will not work on x11 its been a known problem (compromise? not worth it?) probably since higher refresh rate monitors/multi monitor setups became more common.
Here is an article from 2021 mentioning it
It works on Wayland. I have a 144hz and a 60hz monitor and have no issues. Have you checked the display settings when you go to Wayland? I don’t believe my high refresh rate monitor defaulted to the highest and had to go in and change it.
