Catalyst not running after installing it in openrc
#1
so i couldn’t get catalyst to install and run properly after installing openrc 17, 17.01, or after using the manjaro-architect installer
So i tried installing it after the fact and it isn’t working. I install the headers and the kernels for the catalyst but after reboot i get the above error when i tried to run sudo amdcccle.
qt4 is installed also…
Manjaro architect broken now?
#2
I would try catalyst-utils-openrc
#3
ok then. moving on the the dev version…
#4
ok, so maybe you fixed it since i just tried it and the non-free didn’t work? will try again…
#5
or does openrc just not work with catalyst? Currently i’m trying to install it after the fact…
#6
installing that made nop difference
#7
You sure your card isn’t handled by the community drivers?
#8
In xfce systemd I run catalyst without any problems. I have an A8 with an 8553g (I think) apu and an A6 with a 6520g apu. Both run on catalyst really well…
I use manjaro because of overscan issues and because you still support catalyst
#9
I think what @jsamyth said is that are you still using the vesa driver?
Try checking it with this command :
mhwd -li
#10
Ah, I see.
Then why run opernrc?
… /Me Running and ducking…
#11
Because systemd is evil
#12
Yah well all I know to do is to run
Sudo aticonfig --initial
But that doesn’t help
#13
Also… I’m tired now… yesterday and today of trying to get openrc installed with catalyst has exhausted me a lot.
Plus today I walked my cat to the vet in the stroller to have his teeth looked at. I’m spent. It was very hot and muggy… 1/2 hour each way… Smoothie is fiv+ and has some need for teeth extraction…gonna have to plan a trip to Richmond.
#14
Feel for you, our little ginger thug has to go in Wednesday to have possibly all his teeth out, due to some weird auto-immune gingivitis (spelling?). The only people happy about it will be the vet & nurses he wont bite (again)… and a cost of £250.
#15
It’s okay, take your time. I hope in the next trial, you will successfully install catalyst!
#16
catalyst-input and xf86-input-libinput-nosystemd are in conflict
so lets stop making them conflict
we need some mediation here…
#17
well see… i’m using the manjaro architect installer and while the issue no longer seems to be with the installer but a conflict between catalyst and openrc at this point, i dont think it much matters which driver is loading because catalyst isn’t installing automatically like it should via the installer due to this catalyst-xf86 input issue. when catalyst installs, several -nosystemd files get uninstalled and one refuses to uninstall.
@jonathon is this a known issue that catalyst won’t work with openrc or is it something new… what should i do?
#18
> Installing video-catalyst...
Using default
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/catalyst/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Packages (5) xf86-input-elographics-1.4.1-7  xf86-input-evdev-2.10.5-1  xf86-input-keyboard-1.9.0-2  xf86-input-mouse-1.9.2-3  xf86-input-void-1.4.1-3
Total Removed Size:  0.27 MiB
:: Do you want to remove these packages? [Y/n]
removing xf86-input-elographics...
removing xf86-input-evdev...
removing xf86-input-keyboard...
removing xf86-input-mouse...
removing xf86-input-void...
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
resolving dependencies...
:: catalyst-input and xf86-input-libinput-nosystemd are in conflict (xf86-input-libinput). Remove xf86-input-libinput-nosystemd? [y/N] error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Error: pacman failed!
Error: script failed!
#19
I’m not an OpenRC expert (or even user now) - but I do know that Catalyst isn’t well supported any more. AMD have stopped development, and if you’re running Catalyst you’re also using a rapidly ageing version of Xorg (1.17 vs 1.19).
#20
Which is why i am ever so grateful for Manjaro being the only one to continue to support it.
<3 <3 <3 <3
