In December 2025 I have setup Carla with my Nektar Impact GX61 keyboard successfully using some LV2 Plugins.I could achieve this by help in this forum.
I had to reinstall Manjaro on this small laptop again, but now I cannot get it to work again:
I have taken two screenshots, one showing the connections in the canvas external and the other as internal.
When I click on the organ when internal canvas is shown, I can “play” it by the keys in the display. When I click on “Carla” while external connections are shown, I can also “play” it by the keys in the display.
The keyboard shows up on the external canvas. But any connections, I tried to make to the keyboard MIDI connections were unsuccessfully.
The MIDI-Link is using pipewire only = no additional driver or bridge is installed.
Carla settings are:
Engine → Audio driver = Jack
OSC = enabled, TCP port enabled
use specific port 22752 (this setting is the default and not set by myself)
Which steps should I try next?
