Sddm freeze when trying login to my account
Hello
When I try to login to my account all the system freezes after some seconds.
If I try to login as root all is fine.
I need some help please!
Hi @hafid, and welcome!
That sound like a faulty config somewhere.
From your (working) root account, (re)move your $HOME/.config/ directory:
mv /home/<username>/.config /home/<username/.config.backup
Where, you guessed it, <username> is your username.
Then reboot and try again. If it works, then restore thee config files one-by-one until you’ve found the culprit. If, however, it doesn’t work, then report back with the output of:
journalctl --boot=0 --priority=warning..err --catalog --no-pager
Hope this helps!
might be similar like that: Unable to boot after last update - #21 by tommetomme
nov. 25 14:40:21 hafid-hp kernel: x86/cpu: SGX disabled by BIOS.
nov. 25 14:40:21 hafid-hp kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
nov. 25 14:40:21 hafid-hp kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
nov. 25 14:40:21 hafid-hp kernel:  #3
nov. 25 14:40:21 hafid-hp kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
nov. 25 14:40:21 hafid-hp kernel: ata1.00: LPM support broken, forcing max_power
nov. 25 14:40:21 hafid-hp kernel: usb: port power management may be unreliable
nov. 25 14:40:21 hafid-hp kernel: EXT4-fs (sda10): warning: mounting fs with errors, running e2fsck is recommended
nov. 25 14:40:22 hafid-hp kernel: vboxdrv: loading out-of-tree module taints kernel.
nov. 25 14:40:22 hafid-hp kernel: VBoxNetAdp: Successfully started.
nov. 25 14:40:22 hafid-hp kernel: VBoxNetFlt: Successfully started.
nov. 25 14:40:28 hafid-hp systemd-journald[234]: File /var/log/journal/66e7796bf0f84dc88e28111d76bb7570/system.journal corrupted or uncleanly shut down, renaming and replacing.
nov. 25 14:40:29 hafid-hp kernel: r8168  Copyright (C) 2023 Realtek NIC software team <nicfae@realtek.com>
                                   This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                                   This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
nov. 25 14:40:30 hafid-hp (udev-worker)[302]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
nov. 25 14:40:30 hafid-hp kernel: hp_wmi: query 0x4 returned error 0x5
nov. 25 14:40:33 hafid-hp kernel: ATPX version 1, functions 0x00000003
nov. 25 14:40:33 hafid-hp kernel: ATPX Hybrid Graphics
nov. 25 14:40:33 hafid-hp kernel: kfd kfd: amdgpu: TOPAZ  not supported in kfd
nov. 25 14:40:34 hafid-hp kernel: thermal thermal_zone7: failed to read out thermal zone (-61)
nov. 25 14:40:35 hafid-hp kernel: amdgpu: can't get the mac of 5
nov. 25 14:40:48 hafid-hp (uetoothd)[658]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
nov. 25 14:40:52 hafid-hp avahi-daemon[657]: Failed to parse address 'fe80::1%wlp3s0', ignoring.
nov. 25 14:40:52 hafid-hp bluetoothd[658]: src/plugin.c:plugin_init() System does not support csip plugin
nov. 25 14:40:52 hafid-hp bluetoothd[658]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
nov. 25 14:40:52 hafid-hp bluetoothd[658]: src/plugin.c:plugin_init() System does not support micp plugin
nov. 25 14:40:52 hafid-hp bluetoothd[658]: src/plugin.c:plugin_init() System does not support vcp plugin
nov. 25 14:40:52 hafid-hp bluetoothd[658]: src/plugin.c:plugin_init() System does not support mcp plugin
nov. 25 14:40:52 hafid-hp bluetoothd[658]: src/plugin.c:plugin_init() System does not support bass plugin
nov. 25 14:40:52 hafid-hp bluetoothd[658]: src/plugin.c:plugin_init() System does not support bap plugin
nov. 25 14:40:59 hafid-hp NetworkManager[695]: <warn>  [1700919659.8531] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
nov. 25 14:41:00 hafid-hp (mariadbd)[773]: mariadb.service: Referenced but unset environment variable evaluates to an empty string: MYSQLD_OPTS, _WSREP_NEW_CLUSTER
nov. 25 14:41:01 hafid-hp systemd[1]: httpd.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ Defined-By: systemd
░░ The unit httpd.service has entered the 'failed' state with result 'exit-code'.
nov. 25 14:41:04 hafid-hp kernel: amdgpu: can't get the mac of 5
nov. 25 14:41:33 hafid-hp sddm-greeter[976]: QObject: Cannot create children for a parent that is in a different thread.
                                             (Parent is QGuiApplication(0x7ffed0ae7c60), parent's thread is QThread(0x55e740d75e30), current thread is QThread(0x55e740edac30)
nov. 25 14:41:33 hafid-hp sddm-greeter[976]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
nov. 25 14:41:48 hafid-hp sddm-greeter[976]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
nov. 25 14:41:48 hafid-hp sddm-greeter[976]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
nov. 25 14:41:48 hafid-hp sddm-greeter[976]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
nov. 25 14:41:49 hafid-hp sddm-greeter[976]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
nov. 25 14:41:50 hafid-hp sddm-greeter[976]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.21'
nov. 25 14:41:50 hafid-hp sddm-greeter[976]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.22'
nov. 25 14:41:50 hafid-hp sddm-greeter[976]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
nov. 25 14:42:01 hafid-hp ksplashqml[1040]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
nov. 25 14:42:02 hafid-hp ksplashqml[1040]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
nov. 25 14:42:05 hafid-hp ksmserver[1103]: Qt: Session management error: networkIdsList argument is NULL
nov. 25 14:42:06 hafid-hp ksmserver[1103]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.13'
nov. 25 14:42:08 hafid-hp plasmashell[1151]: Checking screens: available: (QScreen(0x563861863010, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x563861863010, name="eDP-1"))
nov. 25 14:42:11 hafid-hp org_kde_powerdevil[1180]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
nov. 25 14:42:14 hafid-hp systemd[1016]: plasma-powerdevil.service: start operation timed out. Terminating.
nov. 25 14:42:14 hafid-hp systemd[1016]: plasma-powerdevil.service: Failed with result 'timeout'.
░░ The unit UNIT has entered the 'failed' state with result 'timeout'.
nov. 25 14:42:14 hafid-hp systemd[1016]: Failed to start Powerdevil.
░░ Subject: L'unité (unit) UNIT a échoué
░░ L'unité (unit) UNIT a échoué, avec le résultat failed.
nov. 25 14:42:14 hafid-hp org_kde_powerdevil[1305]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
nov. 25 14:42:15 hafid-hp kded5[1105]: org.kde.wacomtablet.common: d->name.isEmpty? true
nov. 25 14:42:15 hafid-hp org_kde_powerdevil[1305]: org.kde.powerdevil: Handle button events action could not check for screen configuration
nov. 25 14:42:15 hafid-hp org_kde_powerdevil[1305]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
nov. 25 14:42:16 hafid-hp kded5[1105]: print-manager.kded: unable to register service to dbus
nov. 25 14:42:24 hafid-hp kded5[1105]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
nov. 25 14:42:27 hafid-hp plasmashell[1151]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
nov. 25 14:42:27 hafid-hp plasmashell[1151]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
nov. 25 14:42:34 hafid-hp akonadi_control[1489]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
nov. 25 14:42:36 hafid-hp pulseaudio[1399]: stat('/etc/pulse/default.pa.d'): Aucun fichier ou dossier de ce type
nov. 25 14:42:45 hafid-hp plasmashell[1151]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
nov. 25 14:42:47 hafid-hp kdeconnectd[1290]: kdeconnect.core: Could not query capabilities from notifications server
nov. 25 14:42:47 hafid-hp plasmashell[1151]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
nov. 25 14:42:47 hafid-hp kioslave5[1551]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
nov. 25 14:42:53 hafid-hp akonadiserver[1499]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
nov. 25 14:42:53 hafid-hp plasmashell[1151]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
nov. 25 14:42:53 hafid-hp plasmashell[1151]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x563861ed01a0)
nov. 25 14:42:53 hafid-hp plasmashell[1151]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x563861ed0100)
nov. 25 14:42:53 hafid-hp plasmashell[1151]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x563861ed0100)
nov. 25 14:42:53 hafid-hp plasmashell[1151]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x563861ed00b0)
nov. 25 14:42:56 hafid-hp akonadi_ical_resource[1588]: QDBusConnection: name 'org.freedesktop.Akonadi.Control' had owner '' but we thought it was ':1.49'
nov. 25 14:43:04 hafid-hp plasmashell[1151]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
nov. 25 14:43:04 hafid-hp plasmashell[1151]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
nov. 25 14:43:07 hafid-hp plasmashell[1151]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
nov. 25 14:43:07 hafid-hp plasmashell[1151]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:18:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
nov. 25 14:43:07 hafid-hp plasmashell[1151]: Both point size and pixel size set. Using pixel size.
nov. 25 14:43:07 hafid-hp plasmashell[1151]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:78:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
nov. 25 14:43:07 hafid-hp plasmashell[1151]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
nov. 25 14:43:08 hafid-hp plasmashell[1151]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
nov. 25 14:43:09 hafid-hp plasmashell[1151]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
nov. 25 14:43:09 hafid-hp kioslave5[1551]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
nov. 25 14:43:09 hafid-hp plasmashell[1151]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
nov. 25 14:43:10 hafid-hp plasmashell[1151]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
nov. 25 14:43:11 hafid-hp plasmashell[1151]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
nov. 25 14:43:11 hafid-hp akonadi_indexing_agent[1591]: QDBusConnection: name 'org.freedesktop.Akonadi.Control' had owner '' but we thought it was ':1.49'
nov. 25 14:43:12 hafid-hp plasmashell[1151]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
nov. 25 14:43:13 hafid-hp plasmashell[1151]: trying to show an empty dialog
nov. 25 14:43:33 hafid-hp msm_kde_notifier[1285]: QProcess: Destroyed while process ("pacman") is still running.
nov. 25 14:43:38 hafid-hp plasmashell[1151]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
nov. 25 14:43:56 hafid-hp plasmashell[1151]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
nov. 25 14:44:01 hafid-hp firefox[1850]: Failed to call GetIdletime(): GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.Mutter.IdleMonitor was not provided by any .service files
Hmmm…
Well, I see
nov. 25 14:42:14 hafid-hp systemd[1016]: plasma-powerdevil.service: Failed with result ‘timeout’.
…so maybe that has something to do with it. Let’s see what happens when it’s disabled. From your root account, run:
systemctl disable plasma-powerdevil.service
…and reboot to test again.
If that doesn’t work, please post the above requested logs again. Nice new, fresh ones.
