Hi all,
I can’t seem to be able to write on my mounted samba share with Thunar (1.8.15):
- It works through the terminal
- It works with midnight commander
- It works with any other program I use to write files
- I tried many different ways to set the correct rights (uid=myuser,file_mode=0777,dir_mode=0777,…)
- When I check the permissions through Thunar it’s all correctly set to read&write
- It also doesn’t work with Thunar as root
- I’m using i3wm but it works just fine on my other machine with xfce4 environment (all based on xfce-manjaro)
It seems there is something wrong with thunar. I would prefer not to change my GUI file explorer.
Any ideas?
Thank you!
