No secrets were provided when connecting to WIFI/VPN
Hi !
For awhile now I’ve had issues while connecting to a network with a “no secrets were provided” message and eventually I found out that restarting the networkmanager service somehow fixes this. I did this for some time and after I got fed up with restarting the service on every bootup or I’d get the same no secrets message, I managed to figure out that re-adding the wifi connections I use manually via nmcli made them work normally, meaning I no longer had to restart the service for auto-connect to work. Recently I wanted to connect to a VPN, and I have a .ovpn file which I just import via the GUI but the same “no secrets” problem persists. I also tried to add it via nmcli but got the same result there so It’s high time to fully fix whatever is broken. The problem is that I’m a newbie so I’ve no clue what logs to paste/check or what could be causing this issue. Any tips on where to start ?
Thanks !
Running sudo journalctl -xefu NetworkManager, gives this
NetworkManager[547]: <info>  [1702117913.3737] vpn[0x55d5c1f58bb0,de59c260-bdb1-4a8a-83a1-d6d8568d27ca,"client3_202303301438"]: starting openvpn
NetworkManager[547]: <info>  [1702117913.3746] audit: op="connection-activate" uuid="de59c260-bdb1-4a8a-83a1-d6d8568d27ca" name="client3_202303301438" pid=2255 uid=1000 result="success"
NetworkManager[547]: <warn>  [1702118153.5161] vpn[0x55d5c1f58bb0,de59c260-bdb1-4a8a-83a1-d6d8568d27ca,"client3_202303301438"]: secrets: failed to request VPN secrets #3: No agents were available for this request.
Hi @gez and welcome to the Manjaro forum.
The following links will point you in the right direction. Cheers.
Hello @gez and welcome :wink:
A little reasearch gave me this: 449984 – Plasma 5.24.0 NetworkManager cannot get secrets using DBus when using a proxy Yeah this bug seems to be fixed, but maybe t devs introduced a new bug. I am not KDE User at all, so cannot assist here.
However, I would say that there is a wrong communication on the dbus API. As noted in the bug report enabled “Detect proxy configuration automatically” in the settings produced that misbehavior. Probably something similar or somewhere else. Also non-encrypted secrets didn’t affect this.
Best advice would be reporting that to the devs on https://bugs.kde.org/.
Привет. Удалось решить проблему? Она актуальна также и для GNOME. Смоделировать можно даже не устанавливая OS (загрузившись с USB).
English, please. :roll_eyes:
Sorry :slight_smile:
Hi. Did you manage to solve the problem? It is also relevant for GNOME. You can simulate it even without installing the OS (by booting from USB).
In GNOME, this is preceded by a large output of the form:
gnome-shell[1567]:  JS ERROR: Gio.IOErrorEnum: Ошибка при записи в файловый дескриптор: Обрыв канала
                                                       _writeConnection/<@resource:///org/gnome/shell/ui/components/networkAgent.js:664:29
                                                       _writeConnection@resource:///org/gnome/shell/ui/components/networkAgent.js:663:24
                                                       VPNRequestHandler@resource:///org/gnome/shell/ui/components/networkAgent.js:486:18
                                                       _vpnRequest@resource:///org/gnome/shell/ui/components/networkAgent.js:851:26
                                                       async*_handleRequest@resource:///org/gnome/shell/ui/components/networkAgent.js:815:18
                                                       _newRequest@resource:///org/gnome/shell/ui/components/networkAgent.js:810:18
                                                       @resource:///org/gnome/shell/ui/init.js:21:20
Full log
%user% gnome-shell[1567]: JS ERROR: Gio.IOErrorEnum: Ошибка при записи в файловый дескриптор: Обрыв канала
%date% %user% gnome-shell[1567]: JS ERROR: Gio.IOErrorEnum: Ошибка при записи в файловый дескриптор: Обрыв канала
%date% %user% gnome-shell[1567]: JS ERROR: internal error while writing connection to helper: Gio.IOErrorEnum: Ошибка при записи в файловый дескриптор: Обрыв канала
                                                       _writeConnection@resource:///org/gnome/shell/ui/components/networkAgent.js:671:25
%date% %user% gnome-shell[1567]: shell_network_agent_respond: assertion 'request != NULL' failed
%date% %user% NetworkManager[540]: <warn>  [1702478544.4511] vpn[0x559937761010,638099a5-50cd-4ba4-9a19-44ac580dc22b,"Severstal_mikhail_kapustin_Severstal-vpn"]: secrets: failed to request VPN secrets #3: No agents were available for this request.
It looks like the problem is in the dialog boxes
UPD: 15.12.2023
Hi. I solved the problem (on GNOME) by downgrading the network-manager-applet package (from 1.34.0-1 to 1.32.0-3).
manjaro-downgrade network-manager-applet
