I recently installed Manjaro in my working laptop. It does connect to WiFi, but it gets impossible to use it. I can’t work on my laptop anymore. WiFi gets too slow, and to load 1 single page it takes some 30 minutes. I already tested multiple WiFi networks, in 2 different states in my country. Always the same trouble. That doesn’t happen through the smartphone hotspot.
Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=0d7b8949-703c-4981-afe0-0da33ed5aac8 rw quiet
cryptdevice=UUID=f479f34d-14df-480a-a896-df74249e2a00:luks-f479f34d-14df-480a-a896-df74249e2a00
root=/dev/mapper/luks-f479f34d-14df-480a-a896-df74249e2a00 apparmor=1
security=apparmor
resume=/dev/mapper/luks-a86edf33-7988-4e77-a4b6-85146a1fab66
udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LG product: U460-G.BG32P1 v: 1.0 serial: <filter>
Chassis: type: 9 v: 0.1 serial: <filter>
Mobo: LG model: U560 v: 1.0 serial: <filter> UEFI: Phoenix v: UNCNSF0E
date: 12/30/2013
ID-1: CMB0 charge: 0.1 Wh condition: 36.0/48.6 Wh (74%) volts: 8.0/7.6
model: LG LGC-LGC type: Li-ion serial: <filter> status: Charging
cycles: 1043
RAM: total: 3.71 GiB used: 1.55 GiB (41.9%)
RAM Report:
Topology: Dual Core model: Intel Core i3-3227U bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB bogomips: 15168
Speed: 798 MHz min/max: 800/1900 MHz Core speeds (MHz): 1: 798 2: 798
3: 798 4: 798
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: LG driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Silicon Motion type: USB driver: uvcvideo bus ID: 1-1.1:3
chip ID: 2232:1053
Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.1.5 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: LG
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.7.15-1-MANJARO
Device-1: Realtek RTL8723AE PCIe Wireless Network Adapter
driver: rtl8723ae v: kernel port: 3000 bus ID: 01:00.0 chip ID: 10ec:8723
vendor: LG driver: r8169 v: kernel port: 2000 bus ID: 06:00.0
chip ID: 10ec:8168
IF: enp6s0 state: down mac: <filter>
Local Storage: total: 253.39 GiB used: 12.63 GiB (5.0%)
ID-1: /dev/sda vendor: Samsung model: MZMPC032HBCD-00000 size: 29.82 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 201Q scheme: GPT
ID-2: /dev/sdb vendor: Kingston model: SA400S37240G size: 223.57 GiB
serial: <filter> rev: 0102 scheme: GPT
ID-1: / raw size: 21.36 GiB size: 20.90 GiB (97.84%)
used: 12.63 GiB (60.4%) fs: ext4 dev: /dev/dm-0 label: N/A
uuid: 0d7b8949-703c-4981-afe0-0da33ed5aac8
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
used: 424 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: EFE7-4361
ID-1: swap-1 type: partition size: 8.15 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 label: N/A
uuid: bfc790f5-11e4-4e80-b6f7-a53bc3245fae
ID-1: /dev/sda2 size: 21.36 GiB fs: crypto_luks label: N/A
uuid: f479f34d-14df-480a-a896-df74249e2a00
ID-2: /dev/sda3 size: 8.16 GiB fs: crypto_luks label: N/A
uuid: a86edf33-7988-4e77-a4b6-85146a1fab66
ID-3: /dev/sdb1 size: 450.0 MiB fs: ntfs label: Recupera\xc3\xa7\xc3\xa3o
uuid: B606119B06115E25
ID-4: /dev/sdb2 size: 100.0 MiB fs: vfat label: N/A uuid: 7C12-EBC6
ID-5: /dev/sdb3 size: 16.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-6: /dev/sdb4 size: 96.27 GiB fs: ntfs label: SISTEMA
uuid: 8E0618CB0618B5E5
ID-7: /dev/sdb5 size: 855.0 MiB fs: ntfs label: N/A uuid: B8D2A433D2A3F432
ID-8: /dev/sdb6 size: 125.91 GiB fs: ntfs label: BACKUP
uuid: 0AEEE9DCEEE9C055
Hub: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 8087:0024
Device-1: 1-1.1:3 info: Silicon Motion type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 2232:1053
Hub: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 serial: <filter>
Device-2: 3-4:3 info: Realtek RTL8723A Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 0bda:8723
serial: <filter>
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 206 Uptime: 14m Init: systemd v: 245 Compilers: gcc: 10.1.0
Packages: pacman: 1155 lib: 375 flatpak: 0 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.05
