--> Loading compiler settings: x86_64
==> Cleaning chroot for [stable] (x86_64)...
-> Deleting chroot copy root ...
==> Creating chroot for [stable] (x86_64)...
--> mirror: https://mirror.netzspielplatz.de/manjaro/packages//stable/$repo/$arch
==> Creating install root at /tmp/buildpkg/stable/x86_64/root
-> Installing packages to /tmp/buildpkg/stable/x86_64/root
error: failed retrieving file 'core.db' from mirror.netzspielplatz.de : SSL certificate problem: certificate has expired
error: failed to update core (download library error)
error: failed retrieving file 'extra.db' from mirror.netzspielplatz.de : SSL certificate problem: certificate has expired
error: failed to update extra (download library error)
error: failed retrieving file 'community.db' from mirror.netzspielplatz.de : SSL certificate problem: certificate has expired
error: failed to update community (download library error)
copy the folder /etc/manjaro-tools to ~/.config
Edit ~/.config/manjaro-tools/manjaro-tools.conf and change the build_mirror env variable
# custom build mirror server
build_mirror='https://www.uex.dk/public/manjaro/'
