I can’t update my system neither with sudo pacman -Syu
nor with pamac update
. I just had the same issue as here https://forum.manjaro.org/t/libcanberra-related-dependencies-prohibit-update/70378
which I could solve with the suggested solution. The system is not complaining anymore about the libcanberra part.
Now, when I use pamac update
, I get the following:
pamac update --force-refresh
Preparing...
Refreshing core.db...
Refreshing extra.db...
Refreshing community.db...
Refreshing multilib.db...
Refreshing chaotic-aur.db...
Refreshing sublime-text.db...
Downloading subli (sublime)...
Refreshing core.files...
Refreshing extra.files...
Refreshing community.files...
Refreshing multilib.files...
Refreshing chaotic-aur.files...
Refreshing sublime-text.files...
Warning: balena-etcher: local (2:1.5.120-1) is newer than chaotic-aur (1.5.120-1)
Warning: electron9: local (9.4.4-2) is newer than community (9.4.4-1)
Warning: gnome-wallpapers: local (20201023-1) is newer than community (20201020-1)
Resolving dependencies...
Checking inter-conflicts...
Warning: dependency cycle detected:
Warning: bashrc-manjaro will be installed before its bash dependency
To upgrade (780):
inux-api-headers 5.12.3-1 (5.10.13-1) core
iana-etc 20210624-1 (20210202-1) core
glibc 2.33-5 (2.33-4) core
qca-qt5 2.3.3-1 (Replaces: qca) extra
libpamac 11.0.1-3 (Replaces: pamac-common) extra
tree-sitter 0.20.0-1 community
rnnoise 0.4.1-1 community
To remove (2):
pamac-common 10.0.6-2 (Conflicts With: libpamac)
qca 2.3.2-2 (Conflicts With: qca-qt5)
Total installed size: 324,8 MB
Total removed size: 12,7 MB
Apply transaction ? [y/N] y
Checking keyring... [801/801]
Downloading required keys...
Error: key "0706B90D37D9B881" could not be looked up remotely
Error: required key missing from keyring
Error: Failed to commit transaction
And when I try to update with pacman, I receive the following:
sudo pacman -Syu
[sudo] password for dave:
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 1312,9 KiB 2,60 MiB/s 00:00 [#####################################################] 100%
sublime-text is up to date
warning: balena-etcher: local (2:1.5.120-1) is newer than chaotic-aur (1.5.120-1)
warning: electron9: local (9.4.4-2) is newer than community (9.4.4-1)
warning: gnome-wallpapers: local (20201023-1) is newer than community (20201020-1)
:: Replace pamac-common with extra/libpamac? [Y/n] y
:: Replace qca with extra/qca-qt5? [Y/n] y
resolving dependencies...
warning: dependency cycle detected:
warning: bashrc-manjaro will be installed before its bash dependency
Packages (803)
Total Installed Size: 13359,03 MiB
Net Upgrade Size: 297,58 MiB
:: Proceed with installation? [Y/n] y
(801/801) checking keys in keyring [#####################################################] 100%
downloading required keys...
:: Import PGP key 0706B90D37D9B881, "Chaotic-AUR Wild Bear Node <wildbear.node@chaotic.cx>"? [Y/n] y
error: key "0706B90D37D9B881" could not be looked up remotely
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
I already tried to use the solution proposed in this post https://forum.manjaro.org/t/cant-upgrade-or-install-any-software-key-error/32847
where they suggest removing the keys with sudo rm -r /etc/pacman.d/gnupg
but this did not help.
I have added the chaotic-AUR mirrors. Should I remove them?
I use an x86 architecture with a Ryzen 2600 CPU with GNOME and kernel 5.13.1-3. I also tried with the previous kernel 5.12.16-1 but that did not help either (made the kernel update recently).
Please let me know if there is more information that I need to share with you and please let me know how I can fix this issue so I can update my system again.
