Can't unset Terminal http/https proxy
I can't delete http/https proxy set on the terminal
$ cat $HOME/.gitconfig
[https]
  proxy = fodev.org:8118
[http]
I try these commands but not working:
unset HTTP_PROXY
unset {http,https,ftp}_proxy
& these checked:
/etc/environment
/etc/wgetrc
/etc/profile.d
How did you set the proxy? Do the opposite of that.
That's the problem. I do not remember :sleepy:
In the future, write down what change is made to the system.
You are asking this forum to research for you every possible way to set http proxy. This research is better done by yourself because you have already done it previously. And your search methods should lead you to the same solution again.
