Installed it to try and see if it’d work on proton, game doesnt start and doesnt uninstall from steam either. Deleted it from user/.steam/ but it still doesnt do anything.
Kernel: 5.11.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=7bd052b1-d66c-4450-bc37-7138732e6121 ro quiet udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: VivoBook 15 ASUS Laptop X570UD v: 1.0
serial: <filter>
Mobo: ASUSTeK model: X570UD v: 1.0 serial: <filter>
UEFI: American Megatrends v: X570UD.311 date: 06/14/2019
ID-1: BAT0 charge: 4.3 Wh condition: 38.6/48.1 Wh (80%) volts: 11.7/11.7
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
cycles: 242
Device-1: hidpp_battery_0 model: Logitech Zone Touch Mouse T400
status: Discharging
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 L2 cache: 6 MiB
bogomips: 28808
Speed: 2400 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 2400 2: 2400
3: 2400 4: 2400 5: 2400 6: 2397 7: 2401 8: 2400
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5917 class ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nvidia v: 460.39 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8d class ID: 0302
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 13d3:5a05 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting
display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71 class ID: 0403
Sound Server: ALSA v: k5.11.0-1-MANJARO
vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI modules: r8169 port: d000
bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: AzureWave
driver: rtw_8822be v: N/A modules: rtw88_8822be port: c000 bus ID: 03:00.0
chip ID: 10ec:b822 class ID: 0280
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus ID: 1-8:4 chip ID: 13d3:3526 class ID: e001 serial: <filter>
Message: Required tool hciconfig not installed. Check --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus ID: 00:17.0 chip ID: 8086.282a rev: 21
Local Storage: total: 931.51 GiB used: 75.49 GiB (8.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM2 scheme: GPT
ID-1: / raw size: 467.02 GiB size: 458.69 GiB (98.22%)
used: 75.46 GiB (16.5%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%)
used: 31.9 MiB (12.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 52.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 249 Uptime: 48m wakeups: 7 Memory: 7.66 GiB
used: 2.09 GiB (27.3%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: pacman: 1177 lib: 416 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.3.01
