Hey. Currently I’m facing with sporadic impossibility to switch audio output between my Jabra headset and internal speakers using my laptop with Manjaro.
PS: It works fine if I’ll try to switch my TWS Bluetooth headset to speakers and back.
Here is some technical details about hardware and software. Thanks for your help!
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=6353e529-0af6-46ac-b3e4-580c88d17660 rw quiet
cryptdevice=UUID=9c7aef54-f4d9-4cdb-9089-64e243b78077:luks-9c7aef54-f4d9-4cdb-9089-64e243b78077
root=/dev/mapper/luks-9c7aef54-f4d9-4cdb-9089-64e243b78077 splash
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: HP product: HP EliteBook 855 G8 Notebook PC v: N/A
Mobo: HP model: 8895 v: KBC Version 43.30.00 serial: <superuser required>
UEFI: HP v: T82 Ver. 01.11.00 date: 10/14/2022
ID-1: BAT0 charge: 32.6 Wh (100.0%) condition: 32.6/56.3 Wh (58.0%)
volts: 12.1 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full cycles: 132
Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1765 high: 2394 min/max: 1600/4505 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1900 2: 1978
3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 2138 9: 1600 10: 1600 11: 1916
12: 1600 13: 2394 14: 1600 15: 1916 16: 1600 bogomips: 60705
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 42.0 C
Device-2: Luxvisions Innotech HP HD Camera type: USB driver: uvcvideo
bus-ID: 1-1:2 chip-ID: 30c9:000f class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x069b built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.1-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: bus-ID: 3-1:4 chip-ID: 0b0e:0300 gen: 3 class-ID: 0300
speed: 8 GT/s serial: <filter> lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-4: GN Netcom Jabra EVOLVE 20 MS type: USB
driver: jabra,snd-usb-audio,usbhid
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
chip-ID: 10ec:c822 class-ID: 0280
IF-ID-1: br-3046ea6eec0e state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: kvnet state: unknown speed: 10 Mbps duplex: full mac: <filter>
IF-ID-4: veth0443338 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: veth3d208d7 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 372.35 GiB (78.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1006 size: 476.94 GiB block-size: physical: 512 B
rev: HPS2 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 372.35 GiB (79.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-9c7aef54-f4d9-4cdb-9089-64e243b78077
used: 472 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 48.1 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 389 Uptime: 4h 2m wakeups: 3083 Memory: 30.67 GiB
used: 5.57 GiB (18.2%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1345
pm: pacman pkgs: 1331 libs: 330 tools: gnome-software,pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 14 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.24
