I have a problem:
When i start my computer it doesn’t start manjaro: it starts Memtest; I used “esc” but it only says “Halting” and doesn’t happen anything.
Helpppppppp pleaseee!
I’m using a toshiba satellite c55 with manjaro( I installed it yesterday).
Hi,
only way is CTRL + ALT + DEL to reboot the PC. Then hold SHIFT to enter the grub menu. The selection you make here will be saved for the next boot by default.
Hi:
I did but there is only one thing to select: “Memory tester (memtest86+)”
Whan can I do?
2 things could have happened:
- Grub is not installed correctly
- You have uninstalled all kernels.
The only way is now booting with manjaro boot disk and chroot there to the local disk and fix it.
Ok, thanks you very much
