Can't start xdman
Hi
I installed xdman through software center from AUR after installation xdman won’t start. Also try to start through terminal with no luck
Welcome to the forum! :wink:
xdman won’t work as a standalone application; it’s a browser extension. Fire up your favorite browser, bring up its extension settings and see whether it’s enabled there. :wink:
Yes I know but it won’t start. Don’t know if I have the right java installed
The PKGBUILD should normally pull in the right dependencies.
Are you getting any error messages when you try that?
actually, it does have a GUI @Aragorn
and this is what happens (for me) when I start it from the terminal:
xdman                                                            ✔
[ main ] loading...
[ main ] 15.0.2 5.10.36-2-MANJARO
[ main ] Loading config...
[ main ] Creating folders
[ main ] starting monitoring...
[ main ] Init app
[ main ] Loading fonts
en
[ main ] Loading language en
[ main ] Context initialized
[ Thread-1 ] java.net.BindException: Address already in use
	at java.base/sun.nio.ch.Net.bind0(Native Method)
	at java.base/sun.nio.ch.Net.bind(Net.java:550)
	at java.base/sun.nio.ch.Net.bind(Net.java:539)
	at java.base/sun.nio.ch.NioSocketImpl.bind(NioSocketImpl.java:643)
	at java.base/java.net.ServerSocket.bind(ServerSocket.java:396)
	at java.base/java.net.ServerSocket.bind(ServerSocket.java:350)
	at xdman.monitoring.BrowserMonitor.run(BrowserMonitor.java:186)
	at java.base/java.lang.Thread.run(Thread.java:832)
[ Thread-1 ] instance already runninng
checking for app update
[ Thread-0 ] manifest download response: 200
7.2.11 7.2.11
at this point the GUI appears, after a few seconds delay
I don’t know much about that thing or how it is properly used.
I just installed it to help some guy who had problems with it:
Probleme mit XDMAN
The whole thread is in german, though.
The gist of it is:
I just installed it - it pulled it’s java dependency - and it just started and worked, for me.
As of now, for the other guy as well in the end, apparently.
It requires java-runtime>=11. It runs for me with jre-openjdk (provides java-runtime=15)
What Java version(s) do you have installed and which is default? You can check with:
archlinux-java status
See Java - ArchWiki
Thanks it worked on google chrome well
But wont grab video on firefox. even with browser intergration
Thanks its solved am grateful
