Hello I’m new to Linux
I’m using gtx660 graphics card and using DVI to VGA adapter
my monitor default resolution is 1280 1024 but it dint show up on Display Configuration
I installed and create xorg.conf file with NVIDIA X server Settings and change /etc/X11/xorg.conf
{ HorizSync 30-82
VertRefresh 56-76 in Moniter Section(It Works Fine on My previous distro Popos!)
##got that information from Here :-https://askubuntu.com/questions/235507/xconfig-xrandr-badmatch####
But Unfortunately it dint worked on Manjaro
plz help im now using 1024x768
sry for bad English
Yes it Shows :-
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 39
Current serial number in output stream: 40
Really Thank you Sir,
I did Sudo nano /etc/X11/xorg.conf.d/90-mhwd.conf
and add HorizSync 30-82
VertRefresh 56-76
[[Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 30-82
VertRefresh 56-76
Option “DPMS”
EndSection]]
that two lines in (Monitor Section) there and did reboot
It Works well
now i can see my resolution and may more than past
really appreciate you.
