Hi
I recently updated my monitor, and I have a problem reaching the desired refresh rate of 240hz. The monitor works well on another OS partition on the same system and Manjaro detects it, but not nvidia-settings or xrandr.
If I try to set it with
xrandr --output DP-4 --mode 5120x1440 --rate 240.00
nothing happens.
This is my xrandr
[carlos@ManJaro ~]$ xrandr
Screen 0: minimum 8 x 8, current 5120 x 1440, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 connected primary 5120x1440+0+0 (normal left inverted right x axis y axis) 1mm x 1mm
3840x1080 119.97 + 239.97 59.97
5120x1440 120.00* 59.98
2560x1440 239.90 120.00 59.95
2560x1080 119.88 60.00 59.94
1920x1080 119.88 60.00 59.94
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
640x480 75.00 72.81 59.94
DP -5 disconnected (normal left inverted right x axis y axis)
USB-C-0 disconnected (normal left inverted right x axis y axis)
