I want to use LSP with gopls package. it works very good on kate but when I try to type some code for example:
x := 2
gopls shows an error when I’m in the middle of typing this code and causes the output tab in kate to pop up on every edit. I want to prevent this behavior. when I change the settings from Error to Never, after I apply changes and press OK when I reopen the settings it changes back to default which is Error.
this panel pops up on every edit.
this is the item I want to change. It changes back to default. how can I prevent it?
thanks.
