Excuse me for posting and ninja editing but please return to the previous post for some more info
And more here, especially see the Note
https://wiki.archlinux.org/title/Intel_graphics#Installation
yeah no problem I saw your editing
My inxi -Gxx when commenting # Bus Id …
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 ports: active: DP-1,eDP-1 empty: DP-2, DP-3, DP-4,
HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a60
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Dell
driver: nvidia v: 530.41.03 arch: Ampere pcie: speed: 2.5 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 10de:25a2
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-5:2 chip-ID: 0c45:6725
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: modesetting unloaded: nvidia
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96
Monitor-1: DP-1 pos: primary,left model: CR240DM res: 1920x1080 dpi: 93
diag: 658mm (25.9")
Monitor-2: eDP-1 pos: right model: BOE Display 0x093f res: 1920x1080
dpi: 142 diag: 395mm (15.5")
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics (TGL GT1)
direct-render: Yes
Looks fine. And at the right ID and everything.
Its most certainly modesetting
Another test if you are so inclined would be …
Throw out (or move, whatever) those config files and have mhwd ‘add’ modesetting:
sudo mhwd -i pci video-modesetting
That should work too.
I already have it like posted here
Maybe I should delete i915 or something ? Idk why I have it btw
oops sorry for that I thought I had seen only the hybrid profile.
That does probably mean that profile is not working as intended.
I guess stick with the manual config for now.
The other way we used to do it (back when modesetting was first being adopted) was by just removing the older driver:
sudo pacman -Rns xf86-video-intel
But i suspect that will be tied to some mhwd deps.
erreur : impossible de trouver la cible : xf86-video-intel
Meaning it doesn't find the target
My installed packages with intel in the name
local/intel-gmmlib 22.3.3-1
Intel Graphics Memory Management Library
local/intel-media-driver 23.1.0-1
Intel Media Driver for VAAPI — Broadwell+ iGPUs
local/intel-ucode 20230214-1
Microcode update files for Intel CPUs
local/intellij-idea-community-edition 4:2023.1-1
IDE for Java, Groovy and other programming languages with advanced refactoring features
local/lib32-libva-intel-driver 2.4.1-1
VA-API implementation for Intel G45 and HD Graphics family (32-bit)
local/libmfx 23.1.6-1
Intel Media SDK dispatcher library
local/libva-intel-driver 2.4.1-2
local/libva-utils 2.18.0-1
Intel VA-API Media Applications and Scripts for libva
local/nvtop 3.0.1-1
GPUs process monitoring for AMD, Intel and NVIDIA
local/onetbb 2021.8.0-2
High level abstract threading library (oneAPI Threading Building Blocks)
It may be worthwhile for one of the maintainers to take a look at the mhwd profile.
But for now I suppose keep those config files … they are pretty nonobtrusive … outside of setting modesetting and the busid theres that backlight option … and thats about it.
Many people keep ones for options anyways - I do for options like TearFree.
Okay I’ll do that
One more question about it
Now my nvidia-smi looks like this
nvidia-smi
Thu May 11 04:01:57 2023
| NVIDIA-SMI 530.41.03 Driver Version: 530.41.03 CUDA Version: 12.1 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3050 L... On | 00000000:01:00.0 Off | N/A |
| N/A 47C P8 6W / N/A| 5MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 1089 G /usr/lib/Xorg 4MiB |
Does it mean my nvidia GPU is never in idle mode ?
And I’ll try adding TearFree too
nvidia specifics are going to be a bit beyond me. never had one.
My intel memory is a bit fuzzy.
I use amd now.
Ahah okay
If someone someday has the solution it would be gladly welcomed. I am a bit anxious to not know what is going on x)
Thanks a lot !
