Im a big noob because I just switched from windows to linux. So Im trying to do some c# developing with Jetbrains rider and I think I installed the dotnet sdk and runtime at least they show up in rider. However when trying to run a simple application I get this error message /snap/core18/current/lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.32’ not found (required by /usr/lib/libstdc++.so.6). I have no idea what is causing this so help would be appreciated
Is your system fully updated? If not run
sudo pacman-mirrors -f && sudo pacman -Syyu
and reboot.
I am using Rider - no issues.
What caught my eye was the relation to snap - how is a snap installation related to Rider and dotnet on your system? This doesn’t add up - at least to my knowledge.
I use dotnet from the repo and Rider using the Jetbrains Toolbox App.
Yeah I did that and it said no updates available.
I installed it with snap following the documentation on installing dotnet with snap
I know its not the best way but I tought it might work but it seems like a no
I see.
If you’ll take advice from a seasoned developer I suggest you do as follows
- remove what you have installed using snap (I don’t use snap - so I don’t know how)
When it has been removed it is time to setup dotnet and Rider.
Dotnet is straight forward using pacman (you will get the latest stable)
sudo pacman -S dotnet-host dotnet-runtime dotnet-sdk dotnet-targeting-pack
Next is Rider where you can use the Toolbox or the Rider archive.
As I have a subscription for all the tools I prefer the toolbox - but before that happened I downloaded the archive from the website.
wget https://download.jetbrains.com/rider/JetBrains.Rider-2021.2.2.tar.gz
Then unpack the archive
tar -xzf JetBrains.Rider-2021.2-2.tar.gz
Then cd into the folder and run the launcher from the bin folder
cd JetBrains.Rider-2021.2-2/bin && rider.sh
Thanks it worked. I was away for a few days so couldnt test that but now I have confirmed that that works.
