Can't rotate DisplayLink USB monitor
I have an AOC I1659FWUX 15.6in USB-Powered Portable Monitor (Full HD 1920x1080) with DisplayLink support that I want to use as a third screen to read documents, mostly PDF files.
I successfully installed the DisplayLink driver, and the monitor works great as a third extended desktop in normal (landscape) mode, but I would like to use it in vertical (portrait) mode, so I tried the orientation options of KDE Plasma’s screen settings.
When I select 90 degrees counter-clockwise, this is what I get:
What am I doing wrong?
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
