Now I Have LBRY on my manjaro.
It asks for an update and of-course I can’t update as long as it is deb
And I can’t remember how I downloaded it .
It doesn’t appear in : snap list ,
nor in flatpak list
And it is not an AppImage
although it works very fine
I wish I could remove it completely
I am a new comer to Manjaro linux
any help ? and pls make it step by step .
There’s an AppImage available on their website (which you probably are using) or it’s available in the AUR (Arch User Repository) as lbry-app-bin
Removing an AppImage is as simple as removing the file, probably in your ~/Downloads/
or ~/Applications/
folder.
No it is not an AppImage
can test:
grep -Ei "^Exec.*lbry" ~/.local/share/applications/*.desktop
grep -Ei "^Exec.*lbry" /usr/share/applications/*.desktop
whereis lbry
pacman -Qo lbry
if pacman -Qo lbry
return a package, you are the aur package
