Hi,
I’m new to Manjaro, previously I’ve used Windows…
On Windows my networking works flawlessly but on Linux I’m never able to use the ethernet connection.
I suspect it’s something to do with my network adapter on my motherboard ( ASRock N68-GS4 FX R2.0 )
Here is the ip addr
output:
ip addr 1 ✘
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp0s7: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 70:85:c2:46:5b:83 brd ff:ff:ff:ff:ff:ff
5: enp0s2f1u8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
link/ether 02:50:67:68:66:66 brd ff:ff:ff:ff:ff:ff
inet 192.168.42.86/24 brd 192.168.42.255 scope global dynamic noprefixroute enp0s2f1u8
valid_lft 2761sec preferred_lft 2761sec
inet6 fe80::40d0:c0cd:d208:eb0a/64 scope link noprefixroute
I’m trying to use the enp0s7 connection (My ethernet connection)
When i use the enp0s2f1u8 (my USB tether to the same router) it works automatically…
Hi @nikola418, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as formatted text.
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
Thank you for your advice!
I’m new to this forum, but I’ll try to comply to best of my ability!
Here is additional information about my system:
inxi -v7azy ✔ 23s
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2312 quiet systemd.show_status=1
splash driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASRock model: N68-GS4 FX R2.0
serial: <superuser required> BIOS: American Megatrends v: P1.00
date: 10/05/2015
System RAM: total: 8 GiB available: 7.74 GiB used: 3.48 GiB (44.9%)
Info: model: AMD FX-8350 bits: 64 type: MT MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 8 smt: enabled cache: L1: 384 KiB
desc: d-8x16 KiB; i-4x64 KiB L2: 8 MiB desc: 4x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4018 min/max: N/A cores: 1: 4018 2: 4018 3: 4018 4: 4018
5: 4018 6: 4018 7: 4018 8: 4018 bogomips: 64313
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Oland PRO [Radeon R7 240/340 / Radeon 520] vendor: Hightech
Information System driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-1 empty: DVI-D-1,VGA-1 bus-ID: 02:00.0 chip-ID: 1002:6613
class-ID: 0300 temp: 31.0 C
Device-2: KYE Systems (Mouse Systems) FaceCam 1000X
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-4:4 chip-ID: 0458:708f class-ID: 0102
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: radeon display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-0 model: 24MT600BF serial: <filter>
built: 2020 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1080 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: OLAND ( LLVM 16.0.6 DRM 2.50 6.6.8-2-MANJARO)
device-ID: 1002:6613 memory: 1.95 GiB unified: no
Device-1: NVIDIA MCP61 High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:05.0 chip-ID: 10de:03f0
class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: Hightech Information System driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
bus-ID: 02:00.1 chip-ID: 1002:aab0 class-ID: 0403
Device-3: KYE Systems (Mouse Systems) FaceCam 1000X
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: NVIDIA MCP61 Ethernet vendor: ASRock 939NF6G-VSTA Board
type: network bridge driver: forcedeth v: kernel port: d080 bus-ID: 00:07.0
chip-ID: 10de:03ef class-ID: 0680
IF: enp0s7 state: down mac: <filter>
IF-ID-1: enp0s2f1u8 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung GT-I9070 (network tethering USB debugging enabled)
driver: rndis_host v: kernel type: USB rev: 2.1 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-8:12 chip-ID: 04e8:6864 class-ID: 0a00 serial: <filter>
Local Storage: total: 2.15 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: DataTraveler 3.0
size: 115.5 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: EMTEC X150 240GB
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 61.3 scheme: MBR
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 3.64 GiB fs: iso9660
ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: AB1E-DC8C
ID-3: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ntfs label: hard-drive
uuid: A438F25D38F22E44
ID-4: /dev/sdc1 maj-min: 8:33 size: 500 MiB fs: ntfs label: System Reserved
uuid: DE00E8A700E887BB
ID-5: /dev/sdc2 maj-min: 8:34 size: 222.57 GiB fs: ntfs label: N/A
uuid: 9804F20004F1E164
ID-6: /dev/sdc3 maj-min: 8:35 size: 521 MiB fs: ntfs label: N/A
uuid: 2EEC0358EC0319AB
Hub-1: 1-0:1 info: full speed or root hub ports: 10 rev: 2.0
Device-1: 1-4:4 info: KYE Systems (Mouse Systems) FaceCam 1000X
type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
Device-2: 1-7:5 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 Kyson
type: mass storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 300mA
chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
Device-3: 1-8:12 info: Samsung GT-I9070 (network tethering USB debugging
enabled) type: bluetooth,CDC-data driver: rndis_host interfaces: 3 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 64mA
Hub-2: 2-0:1 info: full speed or root hub ports: 10 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Device-1: 2-1:2 info: Kingston HX-KB4BL1-US [HYPERX Alloy FPS Pro]
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 480mA
chip-ID: 0951:16d2 class-ID: 0300
Device-2: 2-2:3 info: A4Tech USB Device type: keyboard,mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 09da:71b0 class-ID: 0300
System Temperatures: cpu: 42.1 C mobo: N/A gpu: radeon temp: 31.0 C
Fan Speeds (rpm): N/A
Processes: 214 Uptime: 41m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1210 libs: 325 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Also I should mention why I think that the issue is related to my system and not specifically to Manjaro is because I can’t get ethernet connection on any Linux distribution I’ve tried (Ubuntu 18 or 20, Manjaro, Debian, Fedora…)
Well, I tend to think it’s your system as well, especially because the driver seem to be loaded, you have a very recent kernel:
…and from what I can see on this page the device tends to work just fine. And since it also doesn’t work in other distributions, I lean toward a problematic adapter…
Edit:
Although, upon checking that website with the driver again, I noticed it only working, or being tested, or whatever, up to kernel version 6.3. So perhaps you should try Version 6.1, which is the previous LTS version?
Connection using ethernet and connection using tethering is two different methods.
The first is wired - the second is wireless - at least from the phone to the network.
The most likely cause is your cable connection points.
You can check in Network Settings whether the connection is enabled or not.
Possibly enable it manually
sudo ip link set enp0s7 up
Well forcedeth
is reversed-engineered driver for nforce network cards. That means, they developed it through trail&error, since there is no support from nvidia.
It looks like your model is an MCP61:
Probably try this:
- Unplug cable.
- Unload the driver:
sudo modprobe -rv forcedeth
- Then load it again with these options:
sudo modprobe -v forcedeth msi=0 msix=0
- Plugin the cable and try to connect. Maybe restart the NetworkManager:
sudo systemctl restart NetworkManager
Does it work?
The whole system freezes when i try to run
Well then try stopping Networkmanager before and start it after loaded again:
sudo systemctl stop NetworkManager
sudo systemctl start NetworkManager
However… no idea why your whole system freeze. Normally it shouldn’t.
Hi guys, I just wanted to bring you up to date on the matter.
I have solved the issue…
I found the solution which worked for me here:
https://bbs.archlinux.org/viewtopic.php?pid=1551149#p1551149
The solution was to add this line to mkinitcpio.conf:
FILES="/etc/modprobe.d/forcedeth.conf"
and this into /etc/modprobe.d/forcedeth.conf:
options forcedeth msi=0 msix=0
then run:
sudo mkinitcpio -p linux66
(linux66 instead of linux)
and finally reboot the system.
Next time I’ll make sure to invest into a better motherboard since the problem seems to be solely related to the firmware.
Thank you everyone for trying to help!!
I have encountered this issue on many Linux distributions I have tried to run on this system… finally I decided to ditch Windows for good since trying to develop anything on it is pure hell, and was successful.
