My power manager settings were different that I had set them so I tried to look, but can’t open power manager in settings.
[arkansawdave@missi ~]$ sudo inxi -Fmxxxz
[sudo] password for arkansawdave:
System: Kernel: 4.4.248-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.14.3 tk: Gtk 3.24.23
info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: Micro-Star product: GP62 6QE v: REV:1.0 serial: <filter> Chassis: type: 10 serial: N/A
Mobo: Micro-Star model: MS-16J5 v: REV:0.A serial: <filter> UEFI: American Megatrends v: E16J5IMS.11D
date: 01/19/2018
Battery: ID-1: BAT1 charge: 38.6 Wh condition: 39.9/43.2 Wh (92%) volts: 12.2/10.8 model: MSI BIF0_9 type: Li-ion
serial: N/A status: Unknown
Memory: RAM: total: 7.56 GiB used: 1.65 GiB (21.8%)
Array-1: capacity: 32 GiB slots: 2 EC: None max module size: 16 GiB note: est.
Device-1: ChannelA-DIMM0 size: 8 GiB speed: 2133 MT/s type: DDR4 detail: synchronous bus width: 64 bits
total: 64 bits manufacturer: Samsung part-no: M471A1K43BB0-CPB serial: <filter>
Device-2: ChannelB-DIMM0 size: No Module Installed
CPU: Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S rev: 3 L1 cache: 256 KiB
L2 cache: 6 MiB L3 cache: 5.9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41495
Speed: 900 MHz min/max: 800/3500 MHz volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 900 8: 900
Graphics: Device-1: Intel HD Graphics 530 vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: Micro-Star MSI driver: nvidia v: 455.45.01 bus ID: 01:00.0
chip ID: 10de:139a
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus ID: 1-11:5 chip ID: 5986:0683 serial: <filter>
Display: server: X.Org 1.20.10 driver: modesetting unloaded: nvidia resolution: 1920x1080 s-dpi: 96
OpenGL: renderer: llvmpipe (LLVM 11.0.0 256 bits) v: 4.5 Mesa 20.3.1 compat-v: 3.1 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a170
Sound Server: ALSA v: k4.4.248-1-MANJARO
Network: Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0 chip ID: 8086:3165
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Micro-Star MSI driver: alx v: kernel port: d000
bus ID: 03:00.0 chip ID: 1969:e0a1
Drives: Local Storage: total: 960.42 GiB used: 216.81 GiB (22.6%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS721010A9E630 size: 931.51 GiB speed: 6.0 Gb/s serial: <filter>
rev: A3U0
ID-2: /dev/sdb type: USB model: General USB Flash Disk size: 28.91 GiB serial: <filter> rev: 1100
Partition: ID-1: / size: 31.25 GiB used: 19.89 GiB (63.6%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 98.4 MiB used: 298 KiB (0.3%) fs: vfat dev: /dev/sda1
ID-3: /home size: 622.47 GiB used: 196.92 GiB (31.6%) fs: ext4 dev: /dev/sda4
Swap: ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -1 dev: /dev/sda3
Sensors: System Temperatures: cpu: 40.0 C mobo: 27.8 C
Info: Processes: 237 Uptime: 9m wakeups: 2 Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1259
Shell: Bash (sudo) v: 5.1.0 running in: terminator inxi: 3.2.01
