I have been trying to send an email to gmail through nodemailer, but it gave me the following error:
Error: queryA EREFUSED smtp.gmail.com
at QueryReqWrap.onresolve [as oncomplete] (node:dns:209:19) {
errno: undefined,
code: 'EDNS',
syscall: 'queryA',
hostname: 'smtp.gmail.com',
command: 'CONN'
After extensive digging, I found out that the problem is probably due to port 465 being closed (which is the port for smtps. Took me a while to figure out how to know if the port is closed. When checking whether port 465 is closed or not using nmap
here is the output:
Host is up (0.0017s latency).
PORT STATE SERVICE
465/tcp closed smtps
and to make sure, this is the output for my open ports using nmap
as well.
Host is up (0.013s latency).
Not shown: 997 closed ports
PORT STATE SERVICE
53/tcp open domain
80/tcp open http
443/tcp open https
I tried opening the port using iptables
sudo iptables -A INPUT -p tcp --dport 465 -j ACCEPT
but it still won’t open, what am I missing?
You are probably barking up the wrong tree - those are probably incoming traffic - very few firewalls block outgoing traffic.
Are you sure gmail supports 465?
Most likely they are using 587/STARTTLS and you will need to enable client access using app password for your gmail account.
Chain INPUT (policy DROP)
target prot opt source destination
ufw-before-logging-input all -- anywhere anywhere
ufw-before-input all -- anywhere anywhere
ufw-after-input all -- anywhere anywhere
ufw-after-logging-input all -- anywhere anywhere
ufw-reject-input all -- anywhere anywhere
ufw-track-input all -- anywhere anywhere
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:urd
ACCEPT tcp -- anywhere anywhere tcp dpt:urd
Chain FORWARD (policy DROP)
ufw-before-logging-forward all -- anywhere anywhere
ufw-before-forward all -- anywhere anywhere
ufw-after-forward all -- anywhere anywhere
ufw-after-logging-forward all -- anywhere anywhere
ufw-reject-forward all -- anywhere anywhere
ufw-track-forward all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output all -- anywhere anywhere
ufw-before-output all -- anywhere anywhere
ufw-after-output all -- anywhere anywhere
ufw-after-logging-output all -- anywhere anywhere
ufw-reject-output all -- anywhere anywhere
ufw-track-output all -- anywhere anywhere
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:netbios-ns
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:netbios-dgm
ufw-skip-to-policy-input tcp -- anywhere anywhere tcp dpt:netbios-ssn
ufw-skip-to-policy-input tcp -- anywhere anywhere tcp dpt:microsoft-ds
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:bootps
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:bootpc
ufw-skip-to-policy-input all -- anywhere anywhere ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
LOG all -- anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
ACCEPT icmp -- anywhere anywhere icmp destination-unreachable
ACCEPT icmp -- anywhere anywhere icmp time-exceeded
ACCEPT icmp -- anywhere anywhere icmp parameter-problem
ACCEPT icmp -- anywhere anywhere icmp echo-request
ufw-user-forward all -- anywhere
It used to work before on my windows, so I highly doubt that this is the problem. Plus many people use gmail with 465. However, I will try the 587/STARTTLS approach, though it’ll take me some to tell you how it went, since I haven’t done that before so it’ll take me some time messing around.
I am sorry, not sure what you mean
I use gmail with:
Server Name: smtp.gmail.com
Port: 465
User Name: won’t tell
Authentication method: OAuth2
Connection Security: SSL/TLS
It would be unusual if your firewall
or that of the router you are probably going through
would block outgoing connections
(outgoing smb towards the internet is sometimes blocked … but that’s not relevant here)
Your firewall’s output policy is “accept”
and nothing outgoing is blocked as far as I can see
Sorry, i know. All Internet Routers have an integrated Firewall;
the ports you want to be open are likely to be blocked by default in your Routers Firewall…
